Sponsored by: Auxito
Rear ABS Sensor
Old Oct 7, 2007 | 02:47 PM
mdpitt's Avatar
mdpitt
Rear ABS Sensor
Were precisely is the rear ABS sensor, if anyone can give me good detail as I found my front ones and they look ok, will do ohms test later. As I’m not good with brakes the more detail the better, thanks Folks (2003 F150 4x4 SC)
Old Oct 7, 2007 | 02:59 PM
Wilber15's Avatar
Wilber15
in the center housing of the rear diff.....right above the rear pinion.
Old Oct 7, 2007 | 03:11 PM
mdpitt's Avatar
mdpitt
Thanks , does it unplug like the front ones for me to inspect or is it a little different
Old Oct 7, 2007 | 03:27 PM
Wilber15's Avatar
Wilber15
the harness connects right to the sensor, no extension wiring or anything. just unplug at the harness.
Old Oct 7, 2007 | 05:19 PM
mdpitt's Avatar
mdpitt
Thanks for your help, after my big Turkey Dinner (Thanksgiving in Canada) I wiggled under the truck to inspect, it was pretty dirty, so I cleaned then hit two front sensors and rear sensor with cleaner and dielectrict grease, hope this stops the ABS kicking in at low speeds if not I will borrow my friend ohms reader then replace or move onto next thing to eliminate.
Old Oct 8, 2007 | 10:48 AM
mudvayne0882's Avatar
mudvayne0882
Location
THe sensor sits directly on top of the rear differnetial.
