Missing when below operating temp.
Old Oct 15, 2012 | 03:29 PM
mstiles19's Avatar
mstiles19
I have been noticing that my truck (108000 miles) has been missing and running rough (somtimes even surging) untill the engine warms up (eot above 160) Any idea on what could be causing this?
FICM readings are all good, batteries are new. This will happen when i start the truck in the morning and its in the 40s or if I park it for an hour and it just cooled off a little.
thanks for your help.
Old Oct 15, 2012 | 03:31 PM
mstiles19's Avatar
mstiles19
I forgot to mention the truck is not showing any codes.
Old Oct 15, 2012 | 03:45 PM
DP-TunerSales's Avatar
DP-TunerSales
If the truck runs rough when cold but gets betters or even clears up completely once it's up to full operating temperatures I would suspect an injector issue. Unfortunately, this is quite common with the 6.0L platform, it could be a problem with just one injector or multiple units...
Old Oct 15, 2012 | 04:05 PM
mstiles19's Avatar
mstiles19
thanks that is kinda what I was thinking. it does get 100 percent better once it reaches operation temp. Shouldnt a bad injector throw a code?
Old Oct 15, 2012 | 04:34 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
What's your fuel pressure?
Old Oct 15, 2012 | 05:00 PM
bismic's Avatar
bismic
Make sure your oil is changed at the proper intervals and that you are using Motorcraft oil filters. Some people have found that a 5W40 oil and RevX or Archoil has helped injector stiction issues.
Old Oct 15, 2012 | 09:20 PM
Fal-308-Win's Avatar
Fal-308-Win
Check FICM volts under load (going up a hill)
Old Oct 15, 2012 | 09:36 PM
BLADE35's Avatar
BLADE35
Worn inject Orings will cause this issue to
Does your oil smell like diesel Fuel
Watch it over time to see if your Making oil
The Orings will leak fuel untill truck warms up and things expand and seal
Old Oct 16, 2012 | 07:01 AM
mstiles19's Avatar
mstiles19
fuel pressure is 62 and will drop to 58 when accellerating hard towing 10K
I have noticed that when it is cold (not at operating temp) my fuel pressure seems to bounce around.
also this morning when I started the truck it ran fine for the first 30 seconds then it started to miss slightly/shake/run rough
Old Oct 16, 2012 | 07:04 AM
mstiles19's Avatar
mstiles19
Originally Posted by bismic
Make sure your oil is changed at the proper intervals and that you are using Motorcraft oil filters. Some people have fond that a 5W40 oi and RevX or Archoil has helped injector stiction issues.
oils is changed every 5000 miles with 5w40 with valvoilne I also have a bypass oil filter and use motorcraft oil filter
Old Oct 16, 2012 | 07:05 AM
mstiles19's Avatar
mstiles19
i check them pulling my goosneck loaded with my trractor and the readings were right on the money
Old Oct 16, 2012 | 07:07 AM
mstiles19's Avatar
mstiles19
I will definatly check into this I have not noticed the oil level rising but i really dont pay attention to it rising either, i just make sure its not low
Old Oct 16, 2012 | 12:32 PM
mstiles19's Avatar
mstiles19
So is there any way to tell which injectors are being problematic? Once I am done work I will check the oil to see if the level has risen or if it smells like diesel.
thanks!
Old Oct 16, 2012 | 09:00 PM
mstiles19's Avatar
mstiles19
I checked the oil and didnt smell any real strong diesel scent, I then checked the oil level and it seemed like it might be a little high. I do have almost 4000 miles on this oil.
Old Oct 16, 2012 | 09:23 PM
blueline970's Avatar
blueline970
Could also try a bubble test. Tell you if there is bad injector seals.
