Riffraff FRX
Old Oct 15, 2012 | 02:38 PM
creich68's Avatar
creich68
Originally Posted by CSIPSD
No. There is no way for the PCM to know what the fuel pressure is. Need a gauge.
An air pressure or water pressure gauge can be used in a pinch for short term, off the drain valve.
Originally Posted by F250_
Nope. ....
Fair enough. I've been thinking about adding a fuel pressure gauge lately. This may be the time
Old Oct 15, 2012 | 02:42 PM
1fixitman's Avatar
1fixitman
Do you have the early 99 or late 99. If you have the early 99 then you will need a tiny grinder or a carbide rotary file to grind down some of the up pipe to collector connection which is going to give interference to the drivers side on install. You will also need a 1/4 inch square socket to get the square head plug off of your head on both the drivers side and passenger side. DO NOT try to use vice grips or anything other than a 1/4 inch square head socket. They are both in real crappy spots to get to. I hope you have the late 99 because the up pipe to collector fitting will be 5/8 inch to 3/4 inch higher and will not be interference. Look for that socket though or you will be hard pressed to get those plugs out and you will be cursing a lot.
Dwayne
Old Oct 15, 2012 | 02:44 PM
1fixitman's Avatar
1fixitman
If you read alllllll the wayyyyy to the end of the instructions for install on RR site then you will see that there is interference with the early 99's That is why my FRX is still on the bench. That and I want to upgrade to a late99-03 bellowed up pipes, pedestal, GTP38R setup and I will do the FRX when I do all of that stuff.
Old Oct 15, 2012 | 03:09 PM
CSIPSD's Avatar
CSIPSD
Save your money, time and hassle...
Get a H2e type kit, or build you own...
It will cost you 2500 or so to get the 38R on there...
It will cost you less to get a GOOD T4 or T4i kit on there, and you have limitless turbo options then.
Old Oct 15, 2012 | 03:38 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
agreed............switching from e99 to l99 is absolutely a waste of time and money.....
Old Oct 15, 2012 | 04:05 PM
1fixitman's Avatar
1fixitman
Ok. A little it here. I need to know how many quarts of syn 75-140 for a 10.5 sterling rear differential and what dtv to seal with. I am at advance. Sorry for the thread jack
Old Oct 15, 2012 | 04:08 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
3.75 quarts.
JT250
May 22, 2013 05:10 AM
florida_1959
Oct 2, 2010 03:57 AM
PorchFarms
Jan 19, 2010 02:49 PM
iduger
23
Apr 3, 2008 04:37 PM
Robbgt
Dec 22, 2004 08:56 AM
