75 hiboy headlight issue
Old Oct 12, 2012 | 10:05 AM
fordboy772's Avatar
fordboy772
I have an issue the headlights in my 1975 f250 hiboy after about 30 min of driving begin to cut on and off not ficker or dim there either on or off i have replaced the high beam low beam switch and the switch on the dash and still it continues to happen any ideas
Old Oct 12, 2012 | 10:15 AM
91rangerturbo's Avatar
91rangerturbo
Did you check all your wiring? It could be a break in one of your wires. I know if i took a headlight out of my truck i had no lights at all. So if one break in a wire causes one light to fail you loose both lights. I would start there.
Old Oct 12, 2012 | 10:33 AM
mikeo0o0o0's Avatar
mikeo0o0o0
There is a circuit breaker built into headlight switch itself, this is an automatic resetting breaker.
Sometimes, over time the breaker gets weak and trips on and off without reason. But seeing as you have already replaced the switch, it seems that that would narrow it down to two possibilities, either the new switch is also deffective, possible but not probable, or there is a short somewhere in the wiring.
When the lights go on and off, do you hear a "clicking" sound coming from under the dash? The breaker usually will click when it cycles and resets.
The only other thing I could think of would be, like 91turboranger said, a break in the wire, making and breaking contact as you go down the road.
Old Oct 12, 2012 | 10:52 AM
Fordfleettech12's Avatar
Fordfleettech12
I agree with the wiring. Pull the headlights out, check the wires going into them, that would be the easiest thing to check first. Look for loose or corroded terminals. Then follow the harness the best you can looking for rub spots/chaffing areas. Turn the lights on with the truck off and wiggle every connector and harness, see if you can replicate the problem.
Old Oct 12, 2012 | 11:52 AM
montana_highboy's Avatar
montana_highboy
The best 30 dollar upgrade you can do to these trucks...
Heavy Duty Headlight Harness
Old Oct 12, 2012 | 01:47 PM
91rangerturbo
Sweet i need new headlights in the truck. Guess i am going to pick up this also.
Old Oct 13, 2012 | 05:28 AM
fordboy772's Avatar
fordboy772
But if its a wire break why must i i drive 20 to 30 min for the lights to start acting up and no i dont hear any clicking when they go out and even when the truck is parked and off it does it
Old Oct 13, 2012 | 09:25 AM
mark a.'s Avatar
mark a.
My wires rubbed through right up by the core support. Sometimes it wouldn't do it for a long time then at random they would go out.
Tyler S
Apr 26, 2014 10:03 PM
rottenstock
15
Sep 16, 2013 07:32 PM
Myfreeford
Jan 19, 2012 08:47 PM
joe_13894
Aug 27, 2009 04:34 AM
slifer
Electrical Systems/Wiring
May 16, 2004 06:00 PM
