Blinking headlights
Old Jan 5, 2009 | 07:41 PM
joe_13894's Avatar
joe_13894
Blinking headlights
Anyone have problems with blinking headlights?
I had a burned up headlamp connector last summer. No marker lights because the wire was burned up. I was able to get a new connector from Autozone, and I replaced the switch too.
Now I've replaced the headlamp switch twice, picking two different brands because the headlamps will blink once in a while on high beam. Anyone run into this? I'm assuming it's the circuit breaker built into the switch cycling once in a while.
I've looked over the wiring harness, and I don't see an obvious short. Do headlamps bulbs sometimes draw too much current?
Old Jan 5, 2009 | 07:47 PM
Action4478's Avatar
Action4478
You definately have a short ....
Old Jan 5, 2009 | 07:49 PM
Talyn's Avatar
Talyn
https://www.ford-trucks.com/article/...r_Brights.html
This is a pretty old article. (I didn't check the link)
But it is about the ford wiring on our trucks and how to redo it better.
This wont help your problem, but you were asking about the draw.
Perhaps this will give you a few more ideas of places to check.
Old Jan 5, 2009 | 08:18 PM
2 stroke man's Avatar
2 stroke man
my headlights blink when i flick my wig-wag switch! haha
Old Jan 5, 2009 | 08:43 PM
scatgo's Avatar
scatgo
The only time I ever melted a headlight connector was when I replaced the bulb with one that had a higher wattage than stock.
Old Jan 5, 2009 | 09:49 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Check the alternator.
Old Jan 5, 2009 | 09:55 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thats a very good article. Reps sent.
Old Jan 5, 2009 | 10:37 PM
joe_13894's Avatar
joe_13894
?? How would that relate?
Markers stay on, but the headlights go all the way out and come back on about 2 - 3 seconds apart.
Old Jan 5, 2009 | 10:40 PM
joe_13894's Avatar
joe_13894
If anyone is going to put in relays for their headlights, I'd recommend wiring a little different.
Backwards wire the lights! Feed constant 12V to the common terminal of each light. Then a relay for high and low beam grounds one of the terminals. This way, each headlight can get it's own fuse. If there is a short, one light still works on both high and low beam.
Old Jan 6, 2009 | 09:22 AM
Talyn's Avatar
Talyn
I believe he had it set up that way when I read it. *Shrugs*
Old Jan 6, 2009 | 11:44 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Red face
ohh, if the markers lights stay on, is not related with the alternator.
Old Aug 27, 2009 | 12:27 AM
joe_13894's Avatar
joe_13894
I've replaced the bulbs, 3 headlamp switches and gone over the wiring.
A few months after I replace the switch, the blinking starts and keeps getting worse on high beam. Never a problem on low beam.
I'm guessing that the newer switches are just crap and so I've now put a pair of relays in. I wired them Japanese style, with +12V fed to the common terminal. Each bulb has it's own fuse. The high beam or low beam relay grounds the high or low beam filament connection. MUCH better know.
FYI, I did find a bit of weird Ford wiring. The ground wire for the bulbs is a 20 gauge wire, and the ground wire runs in the harness in front of the radiator and back before grounding. I'd guess this was to limit the voltage to the bulb for some reason.
Old Aug 27, 2009 | 04:34 AM
Copedawg's Avatar
Copedawg
I had a problem like this with an old tow truck 7.3 idi I use to drive. b/c there were so many add on after factory lights the lights would flicker. The switches went bad alot, several times a year. Just before I left they said they gave me a ambulance type switch. I worked there for a few more months w/o a problem. I don't know if it fixed it or not but it seemed to last longer than the standard switch. Just my 2 dinars
hunter1897
Nov 6, 2012 07:26 PM
greystreak92
1978 - 1996 Big Bronco
17
Mar 27, 2012 07:53 PM
JasWood
Jul 29, 2009 07:10 PM
bassguy31
1997 - 2003 F150
Feb 24, 2009 02:59 AM
