Blower Motor Upgrade?
Old Oct 11, 2012 | 09:18 PM
1972RedNeck's Avatar
1972RedNeck
As I was searching through some Cummins swap builds the other day, I saw where somebody used a a blower motor and fan from a newer vehicle to increase air flow. I can't find it now that I want to though.
Has anyone done anything like that?
Old Oct 12, 2012 | 04:46 AM
jowilker's Avatar
jowilker
redneck, The fan flow is pretty decent as they left the factory. Don't want to imply that yours may not be doing the job.
Might suggest that you look for ail leaks into the cab that can keep the system from keeping up. I have that issue with my 66.
John
Old Oct 12, 2012 | 07:30 AM
1972RedNeck
The old one kept up decent considering that I had no headliner and really bad window weather stripping. Since it's dead, I would like to put something better in. (That's just the way I am.)
Old Oct 12, 2012 | 04:06 PM
jowilker's Avatar
jowilker
I understand where you are coming from. What I am trying to convey to you is the heater core and fan are engineered to work together. Putting a larger fan in could blow the heat off the core and it not provide hot air for the fan to blow.
Sealing the air leaks can be a better move allowing a factory setup to work at max efficiency.
Hey I hope you can ride til you sweat this winter.
John
Old Oct 12, 2012 | 06:45 PM
1972RedNeck
John
With the old one on high I could get 140* air when it was 0* outside. I could put a stock motor in, but that is boring and I like to tinker.
Old Oct 13, 2012 | 09:11 AM
1972RedNeck
Nobody????
Old Oct 14, 2012 | 03:21 PM
1972RedNeck
To The Top.
Old Oct 14, 2012 | 03:56 PM
williamwilliam's Avatar
williamwilliam
Well I dont know of any other blower motor you could try. If its working right and you have no leaks in your cab it works pretty good the way it is. Like stated above, I can run mine on high for 5 minutes and I have to cut it off or Im sweating.
Old Oct 14, 2012 | 06:09 PM
1972RedNeck
The old one is dead. That cab leaks. I like to tinker. Why not put a different motor in?
What direction does the stock motor spin?
Old Oct 14, 2012 | 08:41 PM
67fordtruck's Avatar
67fordtruck
Maybe a better and cheaper solution would be to replace a stock fan for the dead one and bump up to a hotter thermostat. My old 79 300-6 would run you out of there with every window seal leaking on the highway partially due to a hotter thermostat.
Old Oct 16, 2012 | 05:32 PM
1972RedNeck
From my research I have deduced that 180* is optimum for performance. There are lots of late '80's fords at the junkyard. I will just have to try it myself.
arrowheadfred
24
Dec 19, 2010 06:13 PM
andyman7931
Dec 7, 2009 07:10 AM
Imdok
Nov 26, 2009 02:45 PM
AdamTN
Mar 1, 2003 06:41 PM
rickm5
Electrical Systems/Wiring
Dec 14, 2001 11:07 PM
