buning oil
Old Oct 11, 2012 | 11:09 AM
1969furd's Avatar
1969furd
buning oil
are the ford 4.2 v6's known for burning oil? i am on a road trip and have gone about 4500 miles and burned 1.5 qts since i left home. engine has 62k on it now, had 58k when i left. was just wondering if this is normal or not
Old Oct 11, 2012 | 12:57 PM
SOB Racing's Avatar
SOB Racing
not normal check compression in each cylinder could be a bad ring set
Old Oct 12, 2012 | 02:00 AM
1969furd's Avatar
1969furd
if it is a bad ring set , i am looking at a complete rebuild right? i know the heads, exhaust, plugs,wires, oil pan, crank, crank bearing all need to come out. if i have to go that far(i hope not) is there any perfomance mods i can so? maybe use 4.6 pistons? get the HP and tq from a v8 in a v6 form?
Old Oct 12, 2012 | 09:21 AM
85e150's Avatar
85e150
4.2 bore 96.8 mm
4.6 bore 90.2 mm
Your 4.2 already makes "V8" power. You just have to find the right V8 to compare it to. Compared to most smaller V8s from the '70s and '80s, it's a powerhouse. There is no practical way to boost you power dramatically on that engine.
1.5 quarts in 4500 miles? Not great, but not a reason for a tear down.
Under "warantee" and as a way to shed responsibility for a loose motor, manufacturers will tell you up to 1 qt per 1000 miles is "normal".
What oil are you running?
Old Oct 12, 2012 | 10:29 AM
jr105's Avatar
jr105
According to Ford this is well within what they consider normal oil consumption.
Old Oct 12, 2012 | 12:59 PM
1969furd's Avatar
1969furd
that is normal!!!!!!!!!!!!!! that is BS. this is a brand new motor, if it had 160k ok, but not 63k
Old Oct 12, 2012 | 01:03 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
U think it bs?
We had 01 V10 that would gulp 1 gallon of oil every 5K miles. been doing for about years before we got tired of refill oil so often that it trade in toward 2011 f250.
Old Oct 12, 2012 | 04:47 PM
1969furd's Avatar
1969furd
Originally Posted by Milwaukee1979F150
U think it bs?
ok well i guess then mine isnt so bad. lol this is my newest vehicle, and i am not used to such a new engine burning oil.
Old Oct 12, 2012 | 04:49 PM
1969furd's Avatar
1969furd
Originally Posted by 85e150six4mtod
4.2 bore 96.8 mm
4.6 bore 90.2 mm
oil is 5/20. brand alwasys changes. and i had no clue that a 4.2 had a bigger bore than a 4.6. that is kind of crazy
Old Oct 12, 2012 | 05:26 PM
jr105's Avatar
jr105
I had an Econoline 4.6 that would go through 1 qt between 3k mi oil changes (about the same rate you're talking about), and the dealer told me they wouldn't even look at it unless it was at the 1 qt per 1k mi another poster mentioned.
Old Oct 12, 2012 | 05:37 PM
1969furd's Avatar
1969furd
ok, thanks, i wont worry then
Old Oct 13, 2012 | 12:02 AM
85e150's Avatar
85e150
Yea, it's not great but it falls into the "normal" range unfortunately.
FWIW, the 113,000 mile 4.3 in our Lexus and the 98,000 mile 4.0 in our Exploder use zero between changes.
IIRC, ditto for my 60k 2.9 Ranger V6, 40k 2.3, 70k 300, and a host of others, including my 3.hate in a Mecury Mink--a rental fleet refugee that sank at 60 or 70k after killing a Honda Accord. And our Honda Accord didn't use oil either....
"YMMV" as they say.......
digitalshooter
Modular V8 (4.6L, 5.4L)
Aug 7, 2011 12:45 AM
Amonshax
1997 - 2003 F150
Aug 5, 2010 04:49 PM
medic299
Jul 10, 2009 09:16 PM
tonebone
Feb 17, 2005 02:21 PM
mkoonce
1997 - 2003 F150
Jul 20, 2004 09:11 PM
