Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C 700 points
Old 10-10-2012, 06:47 PM
madrid london's Avatar
madrid london
madrid london is offline
C 700 points
ok i need a set of points...my Autozone, Napa, and O Riellies are of no help.... i have 1973 C700 w/361 engine
Old 10-10-2012, 10:17 PM
rummur s.c.'s Avatar
rummur s.c.
rummur s.c. is offline
Hmm, thats weird. Thought they would be the same as a 360 or 390.. Pull them out and bring them in.. Ask for a parts out of a ford vehicle with a 360 or 390 and see if they're a match..
Old 10-11-2012, 05:43 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by madrid london
I need a set of points. Autozone, NAPA and O'Reilly's are of no help. I have 1973 C700 w/361 engine.
The reason these autoparts stores have no clue is that most older BIG truck parts are not listed on their computers. Inexperienced minimum wage parts clucks is another reason.
The thing is: You have to get the parts clucks to actually look in their paper parts catalogs, usually stashed under the counter.
B8Q-12171-A .. Point Set (Motorcraft DP-12) / Available from Ford and a gazillion autoparts stores.
SAME: ALL 1958/73 FoMoCo vehicle V8 engines (except hipo's with dual point dizzies) / SAME: ALL 1974/75 FoMoCo vehicle V8 engines without DuraSpark electronic ignition.
Ditto: Condenser, rotor, dizzy cap.
Waltz into one a these autoparts stores, ask for points for a 1958 Edsel Ranger w/a 361. Parts cluck will look at you like you just landed from outer space.
This is not a 361 FT engine, it's a slight overbore of the 352, only offered for Edsel's, only available in 1958. The points are B8Q-12171-A
Old 10-11-2012, 07:52 AM
madrid london
parts info
thanks Bill, you are walking Google, or Bing; dictionary hard bound more likely. thank you
Johnspond
Large Truck
06-12-2019 06:13 PM
scf100
Large Truck
02-05-2017 01:08 AM
rsdjcarter
07-25-2009 03:17 PM
ras4434
04-07-2009 06:27 PM
wantaford
03-06-2008 08:33 AM
Quick Reply: C 700 points
