Number Dummy I need Help
Old Jul 25, 2009 | 01:51 AM
rsdjcarter's Avatar
rsdjcarter
I just bought a new Timing Set for my 352. Got it from Edelbrock and they aren't even close to the same. The old cam sprocket has 36 teeth the new one has 48 and is so much larger that it scrapes the cover when in place. Bill, can you see if you can find me the right one here locally? Or steer me in the right direction, Everywhere I go to look for it I get the same Part number a 7808 number ( I know not FORD) it's a Edelbrock number.
Thanks
Old Jul 25, 2009 | 03:10 AM
camperspecial65's Avatar
camperspecial65
Rob, Heres the p/n info on the gears from the handy dandy catalog...hopefully its not been superceded, but even if it has a parts store should be able to hook you up...
Cam gear...C8AZ6256A...36 teeth...
Chain...DOAZ6268A...48 links
Crank gear..C4AZ6306A...18 teeth
Im not sure if the service parts would be nylon coated teeth like the OE cam gear but if not the p/n oughta help a parts guy at NAPA or carQuest hunt them down...
BTW, the carb base gasket # is G26072...CarQuests p/n...xomes in their bag...In looking at my receipt for it...one was 2.19 and the other which was ordered was 6.57...either way, its cheap...
Just for shhets and giigles I will check at my store down here tomorrow and see what I can scare up...
- cs65
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
the new one has 48 HUH? I looked around, found this: FT ENGINE! See btw below. and is so much larger that it scrapes the cover when in place.
You're asking me for help? LOL! I'm beyond help.
C8AZ6256A .. Camshaft Sprocket 36 Teeth / Obsolete
NOTE: C8AZ6256A replaced C3AZ6256A in 1968.
C3AZ uses a camshaft spacer. C8AZ does NOT!
If the spacer is there, remove it!
C3AZ6256A/C8AZ6256A fit: 1963/67 352/390 / 1968/76 360/390.
GAYLEN C. WRIGHT FORD in Heber City UT has ONE = 435-654-4910.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
GREEN SALES CO. in Cincinnati OH has 19 = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
DENNIS CARPENTER OBSOLETE PARTS in Concord NC has FIVE = 704-786-8139.
btw: C8TZ6256A .. Camshaft Sprocket 48 TEETH / Fits: 1964/72 330/361/391 FT ENGINES ONLY!
Old Jul 25, 2009 | 03:32 AM
NumberDummy
Originally Posted by CS65
C4AZ6306A
C4AZ6306A = 1963/71 352/390 Passenger Cars.
C4AZ6306L = 1965/67 352 F100/350.
C8AZ6306A = 1968/76 352/390 F100/350.
Old Jul 25, 2009 | 03:36 AM
rsdjcarter's Avatar
rsdjcarter
Thank you Bill, good to hear from you, hope you are well. I wonder if this was in the wrong box or what? And Thanks again Don for coming by to look at it, I probably would have customized that cover and been in real trouble, See what you can find. I may end up going with the cheaper one just to get going for now, I have to have this thing done in two weeks for camping.
Old Jul 25, 2009 | 03:41 AM
camperspecial65
LOL...I went up there tonight Bill and I had my hunch confirmed...glad I cked the catalog before I left...tooth and link count is a nice thing...I would say its a matter of the guy at the counter not reading something right...the new cam gear was about 5/16 or so larger OD then the OE sprocket that was pulled from it...I wonder what the parts guy will say when he's told he sold a big truck engine timing set!!!! I would love to see that one...
By cheaper...you arent meaning the set I saw tonight I hope...I will let ya know what I find...give a call in the afternoon if you get a chance..
- cs65
Last edited by camperspecial65; Jul 25, 2009 at 03:45 AM. Reason: asked OP question...
Old Jul 25, 2009 | 03:46 AM
NumberDummy
Prolly mis-packaged. Or mebbe it's something Edelbrock has something to do with it.
The guy at Edelbrock that will know for sure is an old pal of mine from the Studebaker Club: Ralph Guhldahl.
Back in the 1960/70's he was a tech writer for Hot Rod Magazine.
Old Jul 25, 2009 | 10:47 AM
masterqi's Avatar
masterqi
Unique name...and yet there must be at least two:
http://en.wikipedia.org/wiki/Ralph_Guldahl
Old Jul 25, 2009 | 03:17 PM
NumberDummy
Father and son...to be exact.
sweetlou1
Oct 24, 2014 09:07 AM
dragonfiregl
Apr 22, 2014 05:13 PM
jaspirr
Mar 5, 2010 11:01 PM
cbfomoco
17
Aug 30, 2007 12:15 PM
97E99B0
Aftermarket Products
Jan 30, 2004 11:16 PM
