C 700 points
ok i need a set of points...my Autozone, Napa, and O Riellies are of no help.... i have 1973 C700 w/361 engine
Hmm, thats weird. Thought they would be the same as a 360 or 390.. Pull them out and bring them in.. Ask for a parts out of a ford vehicle with a 360 or 390 and see if they're a match..
Originally Posted by madrid london
(Post 12360039)
I need a set of points. Autozone, NAPA and O'Reilly's are of no help. :-X15 I have 1973 C700 w/361 engine.
The thing is: You have to get the parts clucks to actually look in their paper parts catalogs, usually stashed under the counter. B8Q-12171-A .. Point Set (Motorcraft DP-12) / Available from Ford and a gazillion autoparts stores. SAME: ALL 1958/73 FoMoCo vehicle V8 engines (except hipo's with dual point dizzies) / SAME: ALL 1974/75 FoMoCo vehicle V8 engines without DuraSpark electronic ignition. Ditto: Condenser, rotor, dizzy cap. Waltz into one a these autoparts stores, ask for points for a 1958 Edsel Ranger w/a 361. Parts cluck will look at you like you just landed from outer space. This is not a 361 FT engine, it's a slight overbore of the 352, only offered for Edsel's, only available in 1958. The points are B8Q-12171-A :-missingt |
parts info
thanks Bill, you are walking Google, or Bing; dictionary hard bound more likely. thank you
