Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
361 gas engine
Old Oct 11, 2012 | 08:31 PM
madrid london's Avatar
madrid london
361 gas engine
now that it's cooling off, i am having a bit of trouble getting my engine to start; manual choke. [the reason i want to replace points]for some reason if the engine does not fire right up the back pressure??? causes oil to gush/squirt out of the oil filter[ a cup]. it is getting to the point i want to put a catch container underneath to avoid the clean up. after it is running it runs rough maybe oil got up in the carb?
ok question how do you start an old engine??? my newer fuel injected , computer controlled cars just fir right up. i need to work on the manual choke too, it is frozen up
Old Oct 12, 2012 | 12:41 AM
85e150's Avatar
85e150
You don't have to start a new thread for every question on this truck.
If your choke is frozen--open I assume--you need to fix that or you will always have difficulty with cold starts.
Oil out of the oil filter? Or air filter? Is it an oil-bath air filter?
Old Oct 12, 2012 | 07:19 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Get the choke working first, that's very important.
With engines with carburetors, when the engine is cold, you need to pump the gas pedal two to three times before you try to start it.
Without the choke, it'll die right away, but if you keep pumping the gas pedal (not too fast), it'll keep running until it gets warm enough to idle.
70FE250
Feb 11, 2016 05:50 PM
7283-F250
General Automotive Discussion
Sep 13, 2015 10:29 AM
twinzilla
Feb 7, 2010 09:40 PM
jeepin
Aug 9, 2003 09:35 AM
Dustin R
Nov 4, 2002 08:00 PM
