Fuel filter
Old Oct 10, 2012 | 11:06 AM
blueoval65's Avatar
blueoval65
Fuel filter
I just bought the 3/8 fuel line tool & fuel filter for my 95 F-150 4x4 5.0. This is the 1st time I've tried changing fuel filter on one of these trucks. Could one of y'all link me to a thread or article that walks me through it? Thanks for your help.
Later
Old Oct 10, 2012 | 12:32 PM
Freightrain's Avatar
Freightrain
I think they changed from my '89 design, which just had plastic clip holding fittings.
Later model needed that line tool. Slip tool over filter side of fitting, and push firmly back under fitting(you are basically lifting a spring up to clear the hump on the filter side). Once back under it, you should be able to slip the hose off the filter. Do the same for both sides. Keep a pan handy for catching gas that leaks out. Few rags are handy too.
Install filter and hook lines up by just slipping over filter ends and push til they "click" over. Give them a gentle tug to confirm proper engagement.
Done.
Old Oct 10, 2012 | 12:45 PM
Evan_P's Avatar
Evan_P
Read first: You have to remove the pressure from the line. To do this open the hood and look for the schrader valve on the fuel rail. Take the cap off and place a rag under and around the valve. With the rag in place press the valve down to bleed off the fuel pressure. If you leave the pressure in the line you will never get the filter out.
To make it easier as well, while inserting the tool into the line, Push the line towards the filter while pushing the tool into the line. This should get the tool all of the way in. Once it click it's just a matter of pulling the line off the filter and putting the new one it.
Old Oct 10, 2012 | 01:53 PM
khadma's Avatar
khadma
Carpenter Local 745
Or Unplug the connector to the inertia switch.
Then start the truck,
Run the truck until it dies.
Both methods are used.
Remain calm when trying to remove filter.
Old Oct 10, 2012 | 02:01 PM
Evan_P's Avatar
Evan_P
The bold part is the key. Cursing and shouting don't help, I tried...
I also tried the inertia switch but my truck sputtered for 5 minutes without shutting down...
Old Oct 10, 2012 | 02:28 PM
ChristopherN's Avatar
ChristopherN
I had alot of trouble getting the rear line off because of the midship fuel tank and the bracket holding the fuel filter in. I ended up loosening the bolts and cutting the back bolt because I couldn't remove the filter bracket since the tank is in the way. After that removing the line was easier.
HAVE PATIENCE. The filter lines are a pain in the you know what to get off. Breathe deeply and make sure the little tool is inserted fully during the whole process.
Just because the pressure was relieved does not mean a small amount of fuel will come out.
Old Oct 10, 2012 | 02:58 PM
whiteboyslo's Avatar
whiteboyslo
Or whack the switch with something and set it off. Doesn't take much. A tap with the handle end of a screwdriver always worked for me.
Just remember to reset it after the new filter is in.
Mike
Old Oct 11, 2012 | 01:56 PM
blueoval65's Avatar
blueoval65
That wasn't nearly as bad as I thought it would be. The lines can be hateful to come off, but not the bear I was figuring on. Thanks for the info fellas.
Later
Asim Khan
Feb 19, 2016 08:04 AM
greenterror
Mar 8, 2008 02:05 PM
zman764
1997 - 2003 F150
May 20, 2007 02:51 PM
wilderness1
Modular V10 (6.8l)
Feb 12, 2006 09:18 AM
Petre
Apr 1, 2004 05:21 PM
