1996 F250 Fuel Filter Woes
Fellas,
I am frustrated with removing the stock fuel filter from my 96 F250!
I have used a tool from Assenmacher and even bought another scissor type fuel filter removal tool from Autozone with no darn luck in removing the left fuel line.
Here's a pic of where Im struggling
Stock Fuel Filter
I was thinking of grinding down the assenmacher tool so I can actually fit the nozzle heads that insert into the fuel line as the nipple from the filter doesnt provide me enough room to close the tool to insert it all the way.
Have you guys found a way to do this before I either cut that nipple off with a dremel or grind down the tool?
Thanks in advance!
Stock Fuel Filter
Thanks in advance!
First get it out of the bracket so you can move it around a little bit, spray a penetrate into the fitting to flush it clean. Myself I follow that up with a shot of automatic trans fluid for lube.
Then push the filter and line together then spin the filter a little to free it up/verify it is free, careful here don't want to force it if rusty and crusty.
Once that done then its time to release it, push the line and filter to each other as hard as you can, then while holding it push the release tool into the fitting and slide the filter off.
Forcing the line and filter hard to each other is key, doing so takes the pressure off those little retainer fingers allowing easy removal of the filter with the tool.
Push the clip off. If you can not get it by hand, use a flat head screwdriver in one hand and twist it inside the two pieces to expand it while pushing with the other hand.
After you get the clip off, then go with what was already mentioned.
I am no expert, but Dremel tool and gasoline might not be your best combo move.
Petre
1999 to 2016 Super Duty
04-01-2004 05:21 PM
kev100
03-12-2003 02:52 PM
