Okay, I searched and didn't find the info. I also checked my owners manual and couldn't completely figure it out. I have a 1988 Ford xlt van (3/4 ton I believe). It has a c6 auto and a 3.54 rear end. It has an auxilary trans cooler, brake controller and a frame mounted hitch. I know the tires and hitch type are a factor, but what type of towing capacity does the van have? The person I purchased it from said he used to pull his 7K pound travel trailer with absolutly no issues and it pulled better than his 454 gasser truck. What do you guys/girls think?
I tried to read the door sticker, but it is old enough it is hard to read.
i believe the e250/350 were designed to tow a maximum of 10k. since you're a diesel, i'm sure you're either a heavy e250 or an e350.
if you plan to spend a lot of time towing heavy or towing up mountains, you might consider swapping the trans cooler for a bigger one, but of course i don't know how big the one there is to start with.
if you have good tires, suspension, and brakes, i say you're safe to tow 10k - but make sure all hitch components are up to the task first. note that they advise using a weight-distributing hitch for anything over 5k
Thanks. The transcooler i an additional one that was added in series with the one that came stock (running through the radiator). I may add a trans temp gauge if I am going to be towing alot through the hills/mountians.
cool. you should have enough cooling for most situations, but the gage would be wise if you're working it hard, and from there you can decide if a bigger cooler may be in order. if you aren't working it excessively, i wouldn't worry about it.
It must be an E350, cause to be honest, I don't think ive ever seen a Diesel E250.
Quite possible. It is titled as a ClubWagon XLT. Was the E350 a 1 ton or a 3/4 ton? Some other members said you were the guy to ask if I had any van questions.
e250=3/4 ton
e350=1 ton
just like the f-trucks
while i've never seen a diesel e250, they do seem to be listed in parts catalogs, though those aren't a reliable source.
e250=3/4 ton
e350=1 ton
I should be able to tell from the VIN, right? Is there a website that can decode it for me? I googled it, but everyone I found only gave me basic info (make,model,yr and engine).....nothing more detailed unless I wanted to pay.
There is a decoder here on FTE, top of your screen, right under the blue FTE logo thing, right in the middle, you'll see a bunch of tabs, the middle one "Articles/Specs", just put your mouse over it, and a list will pop up, and you'll see VIN decoder in that, it's free and gives you all the info you'll need!
And yes i'm the crazy van man here
And pics are a must!
Tried the VIN Decoder. It keeps saying my VIN is invalid. I double and triple checked it on the title and vehicle. VIN is correct.....worked for the guy at the Ford dealership. Guess I will just have to go without.
