C-6 help
Old Oct 9, 2012 | 11:42 AM
77custom408's Avatar
77custom408
C-6 help
I have a 1979 F-100, 460, C-6 and the transmission will not shift out of first, I am taking it in to a local transmission shop to get fixed but I am new to the area and don't know how honest or reputable they are so I was wanting to go in there with a little knowledge of what could be causing it not to shift out of first gear so I don't get ripped off. A new C-6 from TCI cost $1,139 so I don't want to spend anywhere near that at the transmission shop so does anyone know what could be the problem with my transmission and what is a fair price to fix it. Thanks
Old Oct 9, 2012 | 11:53 AM
smokenchoken's Avatar
smokenchoken
you can get a c-6 rebuilt for $350-$600 and it might possibly be either A... low on fluid or B... vacuum modulator is bad........... these are the only things i have had happen personally that gave similar results and most of the time when the tranny went out i had 1st and 3rd just no 2nd but these are just my opinions
Old Oct 9, 2012 | 11:57 AM
77custom408
Thanks for the info
Old Oct 9, 2012 | 12:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be a disconnected vacuum line to the modulator, a bad modulator, a stuck governor, or a stuck shift valve. If the fluid looks and smells normal that usually rules out internal damage. If the fluid is black or stinky, then you probably will need a rebuild.
Old Oct 9, 2012 | 01:29 PM
stuart1's Avatar
stuart1
Many times the KD rod will fall down or become rusted in the KD position.
There must be a small return spring at the carb.
Old Oct 9, 2012 | 06:58 PM
77custom408
Thanks for the replies, I'm gonna take it to the shop and see what they say, and if they give me a bloated price then I will consider a new Street Fighter from TCI although I do not want to drop amount of cash right now on this truck I might have to, hopefully it's something simple and cheap if that exists
JerryP4
18
Mar 28, 2018 10:37 AM
Thinlizzy13
Aug 25, 2015 03:45 PM
DMAN
Dec 3, 2005 05:43 AM
JoeDaddy15
Sep 9, 2004 05:07 PM
boyd laing
Apr 3, 2004 10:07 AM
