Two different ratios
Old Sep 13, 2012 | 08:50 PM
kykell2's Avatar
kykell2
I need a new rear end for my 78 f150 4x4 with a 3.50 ratio. But I've been looking around for awhile and have found 3.55 and 3.54(?) ratios and I was wondering if that difference would hurt or wear anything if 4wd was used on road i.e. in snow and ice?
Also I'm not sure of my front ratio but my door tag said 3.50 for axle code.
Old Sep 13, 2012 | 11:46 PM
85e150's Avatar
85e150
Your truck has a 9" Ford axle, right? What axles are you looking at with 3.55 or 3.54 ratios? You should be able to rebuild or buy a 3.50 9".
If your front axle is 3.50 or close, the change to 3.55 or 3.54 will be ok under the condtions you note.
You're not going to make a 5/8s out of it by putting a 3/4 ton axle in the back....I hope.....???
Old Sep 13, 2012 | 11:50 PM
RichS2659's Avatar
RichS2659
Your rearend is a Ford 9 inch with a ratio of 3.50. Your front axle is a Dana 44 with a 3.54 ratio, a totally different manufacturer. The 3.54 is close enough to not have much effect with wrapup and binding. A figure that has been mentioned in the forums has been 3% difference and under. If somebody makes a 3.55 ratio, you could use that, but the original Ford ratio was 3.50.
Old Sep 14, 2012 | 04:33 AM
kykell2's Avatar
kykell2
Ok, thanks
Old Oct 10, 2012 | 12:29 PM
kykell2's Avatar
kykell2
I'm still searching for the right gear ratio. I found a 9 in out of a 1980 f100 with the gears I need and 31 spline. I was wanting to know if it would bolt up in my '78?
I know that some of those f100s came with a small lug pattern and some with the larger. I just was wondering if the spring perches and width were the same.
nash22
Oct 12, 2011 07:58 PM
NotMyHusbandsF150
2009 - 2014 F150
Jul 5, 2011 07:40 PM
kooper909
Aug 13, 2008 06:44 PM
robertbourque
Mar 24, 2007 07:51 AM
covrace
Nov 18, 2003 10:23 PM
