Hello all. Hope you can help. I have 1965 Ford F100, with 352. I had the motor rebuilt, as I was taking every thing apart I took pictures. I did not take a picture of where the ground wire from the battery hooks to on the engine. Thanks
You'll get a clue where it goes from the length of the wire.
I don't have your engine but pick the closest engine to trans bolt - clean the wire's end and scrape any paint off the block so you have full contact and using an external star washer bolt it down.
There is a flat spot just to the rear or under the alt on the block. Bolt goes into the block there and that is where you attach the ground lead. If you need I can take a pic tommorow and post it up. Should be pretty evident when you find the flat spot Im talking about.
