help with choices
Old Oct 6, 2012 | 03:20 PM
elgemcdlf's Avatar
elgemcdlf
400 hp out of a 460 is less than 1 hp per CI. It is far less taxing on the engine than doing 400 hp out of a W series engine.
Old Oct 6, 2012 | 03:38 PM
lightninquick's Avatar
lightninquick
Originally Posted by benjas101
The reason why I decided against the 460 is weight I am putting it on a f100 and evryone hear tells me that whit the front end so heavy i will have tration problems sorry guys new to
these type of mods
Don't be sorry, no reason for it. It's your truck and only you know what you really need.
Traction issues can be overcome in many ways. That would be my last concern.
I look for best bang for the buck, and if you want around 400hp and you are starting from scratch a bigblock will give you that pretty easy, probably cheaper.
Old Oct 6, 2012 | 06:29 PM
HIO Silver's Avatar
HIO Silver
So it looks like I will go with a 351w and i will do the 5.0 heads mild cam alum intake 4 barel carb any recomendations on distributor type any one using the mallory type?
That's a weak combo... build the 351W into a 408 stroker for some real torque.
Old Oct 6, 2012 | 08:51 PM
willowbilly3's Avatar
willowbilly3
If you work in a junkyard, find something cool, like a twin cam 4.6 or a 5.0 Coyote.
Old Oct 7, 2012 | 12:13 AM
Ford_Six's Avatar
Ford_Six
It doesn't matter if it's a big block or small block, that truck will have traction issues at 400hp. My truck has traction issues at 180hp.
I'll side with those saying a 460 is the key, although a 400 crank shoehorned into a 351c block, with small chamber heads might be a fun thing.
Old Oct 7, 2012 | 07:04 AM
williamwilliam's Avatar
williamwilliam
Thats what I would suggest as well. Bigger is not always better. If I was going for a moderate build, I would go with a 390 (335 HP head motor if you can find one) for a simple "sounds good" motor and have some grunt to it. For a strip racer yeah go with a big cubic inch motor, which i dont think I would start with one of these trucks for that to begin with.
If I was going to build a motor for one of these trucks to have "fun" with, I would build a 351W anyday over a 289/302 or a big block. Turning a small block 9000 RPM's can be a rush. Clevelands are good if built right, but for the same cubic inch gets crappy gas mileage compared to a windsor. Besides, a 1969 351W came with 290 HP, so you dont have far to go to achieve 400HP.....the right cam selection and worked heads (thats the key) and you will get 400HP. If you work at a salvage yard and can get things chaeper, than you are already ahead of the game! Everyone has different opinions, so like mentioned earlier, just do some research and narrow it down to what you want to accomplish with your truck and motor combination.
Old Oct 7, 2012 | 12:12 PM
benjas101's Avatar
benjas101
thanks for the suggestions guys really appreciate it and yes there is too many options tell me if i am off but i hve a free 351w and some free heads of a 97 explorer 5.0l i was thinking cam redo the heads and valves lifters and so on all with a aod tranny 3.73 posi rear end.
Old Nov 14, 2012 | 01:23 PM
benjas101's Avatar
benjas101
more help
SO UPDATE I have dunne .30 over on my piston, 5.0l explorer heads, new valves lifters crower cam, push rods hi sump oil pump 07 crown vic front suspension 04 marauder rear diff 3.55 locking, interior will be off a 02 harley davidson, so my question is what tranny do you guys recomend for both strip and highway mileage any help thanks .
Old Nov 14, 2012 | 01:24 PM
benjas101's Avatar
benjas101
and yes i will be oing a shift kit on watever tranny i use
52willys
Jun 16, 2014 08:36 AM
TMI
Jun 28, 2010 11:20 PM
slayerman54
66
Mar 30, 2010 09:55 PM
havi
26
Sep 26, 2007 04:24 PM
michigandrake
Feb 11, 2005 11:54 PM
