1978 - 1996 Big Bronco
Wiper Switch?
Old Oct 5, 2012 | 08:16 AM
89BlueBronco's Avatar
89BlueBronco
Wiper Switch?
Think my eyesight is getting really bad.
I need to replace the wiper switch in 89 Bronco. Got ***** off and panel popped away. It "looks" like there's a C-clip on the shaft of the switch. It's not coming off. So is it a C-clip? Is there a trick, or did the PO crazy glue the **** on there?
Old Oct 5, 2012 | 03:25 PM
GruesomeJeans's Avatar
GruesomeJeans
I assume it is the 89 in your name? from a picture i saw on a new switch (if it is not the kind mounted on the column) There might be a nut on the outside part that you loosen and pull the assembly through the back. But i am not sure completely as i have nover pulled my 78's switch out.
Old Oct 5, 2012 | 08:50 PM
CS79bronco's Avatar
CS79bronco
To get the **** off, use a small flat screwdriver & push on the flat spring holding the **** on. Push the spring into the **** & slide the **** off at the same time. Once you get one off you'll see how easy it is. The ***** on the heat/AC controls come off the same way.
mark460
Dec 10, 2008 12:32 AM
boflaade
Dec 27, 2003 11:25 PM
nickmobile67
Aug 11, 2003 11:10 PM
Boltgunner
Sep 16, 2001 07:08 AM
fast freddie
Aug 12, 2001 04:11 PM
