Glow Plug Starting Problems!
In the morning when I go to start my engine occasionaly the glow plugs won't cycle. This makes it almost impossible to start the engine due to the cooler 50 degree climate I live in. The strange thing is the "wait to start" lamp will come on for about 5 seconds turn off, so I'll crank the engine but it will not start. Most of the time during and after the "wait to start" indicator turns off I can hear a clicking noise due to the glow-plugs cycling. (If I hear the "clicking" I know the engine will start) When I have the problem there is no clicking noise and my battery voltage gauge doesn't jump around. When I don't hear my glowplugs "cycling" I turn the key to the off position then turn it back to the run position. Sometimes I have to do this at least 5 times before the glow plugs will turn on.
What should I check? Is there anything I can do? Why does the "wait to start" lamp turn off even if the glowplugs didn't turn on? This problem usually only happens once or twice a day. Sometimes the glowplugs work fine. Could it be the controller?
Please write back with any help regarding my situation.
Thanks
