Questions about Water Pump
Old Oct 4, 2012 | 08:22 AM
Supercab's Avatar
Supercab
Wink Questions about Water Pump
(1) Do I need to use Teflon tape on the threads of the water fitting?
(2) Should I replace the rubber "O" ring on it? if so where do I get one?
(3) Should I use Teflon tape on the threads on the coolant temp sensor?
(4) Is Plumber's faucet lube considered the same as NAPA's Syl-Glide?
-Acording to UPS Quantum View my NEW replacement Water Pump should be here on Friday afternoon-guess what I'm doing Saturday??-lol
Old Oct 4, 2012 | 09:38 AM
timmyboy76's Avatar
timmyboy76
1) I did
2) i did, came with new pump.
3) i did
4) dunno
Old Oct 4, 2012 | 09:47 AM
Supercab's Avatar
Supercab
Thanks Tim! I've forgotten IF the first Airtex pump came with a new seal for the water fitting...guess I'll see when it gets here.....kinda looks like I could use a garden hose washer there if it doesn't.....
Old Oct 4, 2012 | 07:44 PM
dagren99's Avatar
dagren99
Might want to install a coolant filter & get the upper hose for the amb w/ 2 alts that goes around the serp belt - makes changing belts a ton easier. One tip - pull the degas bottle and set it aside makes the job a ton easier.
Old Oct 4, 2012 | 08:56 PM
DND58's Avatar
DND58
I used a product called plumbers faucet and valve grease for lube on water pump inlet o-ring/thermostat o-ring, ...with good results.
Old Oct 5, 2012 | 04:46 AM
Supercab's Avatar
Supercab
Thanks Guys!! reason I asked about the plumbers faucet lube kinda doing the same thing as NAPA's Syl-Glide is all my local NAPA's have closed up and I can get the faucet lube at Ace Hardware.....
6ohman2004
Dec 26, 2024 12:49 AM
Georgeandkira
1997 - 2003 F150
Jun 24, 2013 11:20 AM
Epd444
Apr 26, 2012 11:18 AM
Firefighter 1406
15
Feb 16, 2011 07:30 PM
dustinova
Nov 18, 2007 10:16 AM
