Sponsored by: Auxito
Water pump lube
Old Jun 24, 2013 | 11:15 AM
Georgeandkira's Avatar
Georgeandkira
Water pump lube
Hello, Is there any benefit to adding water pump lube to a 4.6L engine? There's smelly, old looking coolant in my friend's "new" 1997 F-150 so a flush is in the immediate future. I'm going to suggest using G-05 coolant over conventional green due to its longer life. Should water pump lube be added? Kira
Old Jun 24, 2013 | 11:20 AM
Bluegrass 7's Avatar
Bluegrass 7
Be sure the antifreeze is speced for Ford use.
Normally you don't need to add anything extra.
Good luck.
6ohman2004
Dec 26, 2024 12:49 AM
just_waitin
Jun 18, 2007 10:39 PM
Saguaro_7.3
Nov 23, 2005 09:22 PM
Tasslehoff13
Jul 10, 2004 11:47 PM
Larry Heath
Nov 2, 2003 07:31 PM
