EGR Problems
Old Oct 2, 2012 | 08:41 PM
oceansun1984's Avatar
oceansun1984
EGR Problems
My EGR in my 2006 F350 6.0L seems to be giving me the famous problems it's known for.
3 months ago I was getting the black and grey smoke when starting from stopped position. I took the egr valve out and it was caked. I cleaned it almost shinny new. Now today 3 months later it has done it again. I took it apart and cleaned it again and it seemed to run fine. Now it's doing it again, get into the truck two hours later and its fine. It seems to be intermittent. What is causing this to build up with carbon so quickly? Should I just replace the egr valve or get rid of it all together and get a egr delete kit? HELP!!!!
Old Oct 2, 2012 | 08:58 PM
Yahiko's Avatar
Yahiko
How much time do you spend idling ?
If the answer is a lot then do the high idle mod
and use it when you let the truck sit and idle.
Sean
Old Oct 2, 2012 | 09:01 PM
BLADE35's Avatar
BLADE35
Im all for EGR DeLEATE but thats your deal there
All the SOOT Buildup is likely from Improper combustion Bad Fuel Thermostat Cold IDK could be a few things
Somethings wrong if its sooting up that fast
And Your Intake Manafolds and sensors within iy are Clogged up to probably needs pulled and cleaned
A deleate would solve some of it
But regaurdless you have to figure out why its not Combusting properly to really fix
Old Oct 3, 2012 | 02:55 PM
RideDiesel88's Avatar
RideDiesel88
On my '04 ive had the EGR valve disconnected for about 6 months now because i was having some issues as well. Black smoke at low rpms n lack of power. I unplugged it and all that exhaust is going to my turbo now so i get alot more throttle response. BIG difference i was very suprised. I heard with you '06s it might set a code tho so i dont know. Either way im deleting my whole system this weekend along w oil cooler. Also when you clean your valve make sure you dont get any solvent in that weep whole to mess up the actuator.
ash289
Dec 7, 2012 09:22 AM
tinman565
Nov 13, 2011 04:28 PM
Erik17
Jan 7, 2010 11:29 PM
FMC
Aug 20, 2009 06:00 AM
JIM_C
Aug 11, 2008 11:37 PM
