Glow Plug Relay
Old May 18, 2003 | 11:35 AM
lm23's Avatar
lm23
Glow Plug Relay
Still having real bad exhaust smoke problems untill the truck is warm. I understand that there is a relay in glow plug circuit that could be at fault. Where is this relay located?
Thanks,
Bill
Old May 18, 2003 | 05:06 PM
Quadzilla's Avatar
Quadzilla
Glow Plug Relay
It's under the decorative engine cover, mounted on top of the passenger's side valve cover. It looks just like a starter solenoid.
Old May 20, 2003 | 03:31 PM
The Grinch's Avatar
The Grinch
Glow Plug Relay
I don't think the relay is the problem. The relay just turns on the glow plugs for 2 min. then turns them off. Are you losing coolant or burning a bit of oil? Smoke in the exhaust when you get on the throttle with turbo boost is unburnt fuel. What exactly are the cold conditions. Unless it is below freezing, my truck doesn't smoke.
Old May 21, 2003 | 06:14 AM
Quadzilla's Avatar
Quadzilla
Glow Plug Relay
Another possibility is that you've got a problem with your injector O-rings. Mine smoked more before changing them.
Old May 21, 2003 | 09:15 AM
lm23's Avatar
lm23
Glow Plug Relay
Thanks for the replies. Here is a bit of history on how/when this started. I only use this truck on weekends, and it is used to pull a 40' gooseneck race car trailer. Two weeks ago we left the shop here in Plano TX to go to Muskogee OK. About 30 miles north of here, stopped and filled at a Loves, in McAllester OK stopped and topped off the tank at a Texaco truck stop. (we make this trip on a regular basis and usually get fuel at these same places) Got to Muskogee, was there from about 5pm untill Midnight, when I started the truck to leave is when started smoking - it was not cold outside at all, I would guess still in the 70's. Once the temp gauge got above the "C" it quit smoking and ran fine. Stopped in McAllester at the same place, topped off the tank. Started it there - no smoke, motor was still warm -- drove non stop back to Plano. Gauges all read normal, usual amount of power, same fuel mileage, etc.
The next day when I started it after it sat, it smoked. No loss of coolant, motor oil is fine. I drained and changed the fuel filter and filled the bowl with Lucas conditioner. I went to a local station here in town and put in some fresh fuel and treated it with Lucas. Went to local track here in Dallas area Saturday nite, same thing, really bad smoke untill it warms up.
The closest dealer that will service the truck for me is about 40 miles away, that is why I was hoping to be able cure it myself. Looking at the paperwork from the last time it was in for service in late August 2002, it had the injector o-rings replaced at that time. The current mileage is at 49,489 and I have done all the routine maint. myself since I bought it with 9,000 miles on it.
Thanks in advance for any more help.
Bill
Old May 31, 2003 | 10:52 PM
garth's Avatar
garth
Glow Plug Relay
I am looking at buying a 2000 crewcab with the powerstroke that did the exact same thing as IM23 described. I would really appreciate any replies on what would be the cause and if I should go ahead with the purchase.
1976 F-250 crewcab 4X4 460 auto
Old Jun 2, 2003 | 09:14 AM
lm23's Avatar
lm23
Glow Plug Relay
I ended up taking it to the dealer. It turned out to be bad injectors. Truck is still under the 5yr 100,000 mile warranty, so the out of procket cost was a total of $100. It is fine now, in fact it seems to run better than when it was new.
Old Sep 8, 2006 | 10:44 AM
Tmack's Avatar
Tmack
Thumbs up Glow Plug Relay
Try the fuel filter - when my truck starts smoking a bit it's the first thing I change.
bobwhyte2002
May 6, 2012 10:30 PM
guywhalen00
Feb 8, 2009 04:24 PM
chombine
Oct 18, 2006 07:04 PM
proford460
Dec 23, 2004 04:49 PM
oktso20
Nov 8, 2004 06:50 AM
