Starting
Old Oct 2, 2012 | 11:28 AM
Power-smoker's Avatar
Power-smoker
Starting
I have a 2002 F250 7.3L, and sometimes it doesn't start right away. Every morning when i start it, it fires right up, but if i shut if off after running for a while and try to start it again usually within an hour, it will crank over a little while longer before it starts. Is this bad or dirty injectors, or worn glow plugs? Anyone help me out here?
Old Oct 2, 2012 | 11:39 AM
riverrat41's Avatar
riverrat41
Welcome to FTE.
The injectors in these trucks are fired by high pressure oil which is built in the HPOP(High Pressure Oil Pump)It may take a few revoltions of the motor for them to fire.I think you are fine but if you live around someone with an Auto Entegrity,they can put it on your truck and check things out.
Baatzy
Nov 4, 2015 01:17 PM
guthrie&co
Jan 16, 2014 01:26 PM
Milwaukee1979F150
23
Jun 20, 2011 01:09 PM
whitesdford
19
Dec 27, 2008 03:56 PM
derekc
Aug 24, 2003 01:34 PM
