please explain these Codes.
Old Oct 1, 2012 | 09:47 PM
Canadianpowerstroke's Avatar
Canadianpowerstroke
Well I figured out the bullydog GT tuner and ran the communications to the computer. This what I received
P0069 manifold absolute pressure
- barometric pressure correlation
pO487 electric gas recirculation
Throttle position control circuit
P1000-OBD II monitor testing incomplete
and since i have sold off the Bullydog tuner I have a check engine light that is on all the time and I see the wrench that is lit up every once inwhile. i wont know til i get my Dashboss in the mail.
Old Oct 2, 2012 | 12:11 AM
mmm635's Avatar
mmm635
So what the heck does this mean. And it seems that my coolant starting out runs like 20-30 f higher then the engine temp and them it drops does this make sense
Sounds like you might need to replace your MAP sensor. Also, it sounds like your thermostat might be sticking. Change it and flush your system and replace any other parts that have not been replaced, and aging in your cooling system.
Old Oct 2, 2012 | 10:06 AM
Canadianpowerstroke
Well mt coolant was just power flushed about 3 weeks ago full and reverse.
Old Oct 3, 2012 | 07:58 PM
vagunter's Avatar
vagunter
I have a bully dog and a scan gauge. In my opinion don't trust the codes on the bully dog. I have some erroneous codes on the bully but come up clean on the scan gauge
Old Oct 3, 2012 | 08:11 PM
BLADE35's Avatar
BLADE35
you need a Gauge that will read MAP and BARO sensor Live Values
has batterys been unhooked recent????
Your Temps sound normal for warmup ECT Leads then hits 190* and EOT will Pass but hard to know if thats what you ment with engine temp
Old Oct 3, 2012 | 09:40 PM
Canadianpowerstroke
Ya pretty much Benny I sent ya a PM
Old Oct 30, 2012 | 02:16 PM
Canadianpowerstroke
can some one please help me with this
Old Oct 30, 2012 | 02:47 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Does the truck run? Sounds like you have to clear the codes and run the truck for 20-50 miles at different speeds and stop it...turn off, restart and run again while on that trip. Then look to see if any codes were set.
Old Oct 30, 2012 | 04:05 PM
Yahiko's Avatar
Yahiko
You will get the P1000-OBD II monitor testing incomplete
after the batteries have been unhooked and/or a code clear has been done. It's
there so the smog guys know you reset something. It will go away after so many miles
are on the clock and a few other conditions have been met. There is a list of steps
to take to clear it faster in the Tech Folder if I recall right.
Also did you do an EGR delete ? I forget if you did or not. If you did I hope
that you saved the valve and plugged it back in and stuck it in the valley.
And please keep asking questions. Because people learn things that they
did not know they needed to. I am still learning from other people's
questions.
Sean
P.S. Is it snowing there yet ?
Old Oct 30, 2012 | 05:37 PM
Canadianpowerstroke
yes the truck runs ok i will do that
questions.
Sean
thanks Sean no i never did the Delete either and it snowed for 1 night and then its all gone. otherthen that its been just grey out
Old Oct 30, 2012 | 08:31 PM
BLADE35's Avatar
BLADE35
I thought you got a New truck???
Old Oct 30, 2012 | 09:51 PM
Canadianpowerstroke
Nope not me Benny I am selling it thou to much work for me
Old Oct 30, 2012 | 11:19 PM
BLADE35's Avatar
BLADE35
So whats DB showing for
Baro
MAP
AT KOEO????
Unhook batts and turn headlights on for half hour clear these others and see what comes Back
ldunston7621
Apr 24, 2015 01:42 PM
pcatanza
1997 - 2003 F150
Oct 21, 2007 09:03 PM
revolutionabe
Jul 10, 2006 12:30 PM
Sethw3
Texas Chapter
Aug 31, 2004 10:55 AM
