I was attempting to realign my clutch disk the other day before installing my tranny and I made this creation.
Its a "6 extension with misc. sockets that fit inside one another that matched the diameter of the corresponding parts of the spline I was trying to imitate. The duct tape was used to minimize the slop and it worked, slid right in...
i just keep the front piece off of an old junk tranny it's only 4 bolts slides right out and its guaranteed the right size but good job on the ingenuity if i didn't have the right tool i could see myself doing something like that
Good thinking. I have had to punk before, a long time ago though One time. I actually put the disc and pressure plate on the tranny, stabbed it and then bolted the pressure plate on.
I've always loosely bolted plate up, then held disc in "center" and then snug bolts to hold it. Then run my fingers around the outer edge of the pressure ring and feel if the disc is on center. That gets it more then close and usually never a problem getting transmission back in.
Nothing wrong with making a tool. I've tried those plastic ones that come with clutch kits but found they are too sloppy and end up allowing disc to drop down too much. Always had better luck just checking with my fingers.
The plastic ones are so sloppy in the pilot there is no way to get them "centered" no matter what you do. At least on the couple of the ones I've seen. I always just run my fingers around the plate.
For the common ones in my hot rods, I have broken input shafts I can use which fit tight.
