Access to Drivers' parking light?
Old Sep 30, 2012 | 04:38 PM
truckerbear's Avatar
truckerbear
One of my parking lights on MY side is out...so I got the light replacements, and now have un done two screws at the top with the hood raised. What else do I have to unscrew or pop loose to get to the place to switch out the light?
Old Sep 30, 2012 | 04:44 PM
danr1's Avatar
danr1
There are two nuts on studs down below, from the backside of the core support, remove those and the turn/marker and headlight bezel will come off.
Those to nuts are hidden from view, hole through core support to get to them.
Often what happens is the nut is frozen to the stud so the whole thing turns unscrewing from the plastic bezel.
I can try and get you a couple shots pointing where the bolts are if you need it.
Drivers side remove the rad/windshield reservoir, passenger remove the battery to access them.
Old Sep 30, 2012 | 05:21 PM
truckerbear
OK I got the antifreeze container off to the side....maybe I will take you up on the pictures cause when I look down in there I can't see what to undo. I am on the drivers side. Send some pictures
Old Sep 30, 2012 | 05:38 PM
Diesel_Brad's Avatar
Diesel_Brad
You cant see the bolts. You have to feel for them
here are some shots of what it looks like off the truck and how it would look if the battery tray and inner wheel well was not there
Off the truck looking at the back of the paring light and bezel(11mm nuts)
Note access holes in radiator support to reach nuts
same thing but looking down
Old Sep 30, 2012 | 05:41 PM
danr1's Avatar
danr1
Getting some pic's but not thinking you'll really need them.
The access holes are directly left and right of the turn signal light socket.
Hole toward the fender is set on a angle and square, hole toward the center of the truck is round.
I circled the access opening in black,
Old Sep 30, 2012 | 06:26 PM
truckerbear
Ok Thanks! There was a lock nut on one side of the anti freeze cont. and it was crazy taking it out.
I looked on down in there and saw where your access places are. The sun is going down so I will resume this tomorrow eve. I guess this is the proceedure for the head lights also huh? Well I have to learn it some time right?
Old Sep 30, 2012 | 06:50 PM
Diesel_Brad
If you need to change JUST the bulb for the blinker or headlight, there is no need to remove anything other than the bulb
Old Sep 30, 2012 | 07:59 PM
truckerbear
It's the parking light-- I thought at first that the front would pop right off (something like the tail lights do...) But I un did the top screws first under the hood and then started tugging....then I said 'oh %#@!, I gotta go down in there.
Yeah- its just the buld that needs replacing.
Old Sep 30, 2012 | 08:09 PM
Diesel_Brad
If it is the 3157 marker/turn bulb, no need to tear everything apart. But if it is the marker light next to the headlight or the one next to the turn signnal, then you have to take it apart
Old Sep 30, 2012 | 08:16 PM
truckerbear
It's not the blinker or the headlight...it's the smallest one at top and closest to the street,. I call it the parking light. let me see if I can zoom in and get you a photo of it. (this is crazy)
Old Sep 30, 2012 | 08:24 PM
truckerbear
Lets see if it will let me post a photo here...
https://picasaweb.google.com/1074666...12483419383266
Old Oct 1, 2012 | 07:57 AM
Diesel_Brad
Pic dont work
If it is the one next to the headlight, then YES you have to remove the bezel and turn signal lens
kramttocs
Feb 11, 2019 09:14 PM
sean9049
Mar 21, 2016 03:02 PM
gherb1997
1997 - 2003 F150
Nov 10, 2008 10:11 AM
Putt
Jul 12, 2004 03:55 PM
paul 123
1978 - 1996 Big Bronco
Apr 22, 2003 04:47 PM
