which engine to go with
Old Oct 2, 2012 | 10:18 PM
elkarcher1716's Avatar
elkarcher1716
Originally Posted by 2002fx4122
I think it depends on what year the 460 is, if you could get the numbers off the heads or the block. 460's built before emissions really have some power in stock form. look for C8VE or C9VE or D0VE
just found out Its newer than needed. smog and all that. Dont really want to mess with it. Sticking with the 360 and going to rebuild for cheap. thanks for the imput though
Old Oct 2, 2012 | 10:22 PM
elkarcher1716
Originally Posted by mikeo0o0o0
I made a 390 out of my 360 when I rebuilt it. I used an Edelbrock #2105 Performer manifold. I used this manifold so I could also use the exhaust crossover. If you're going to run headers then the Edelbrock 7105 is the same manifold without the exhaust crossover.
I'm also using (initially) a Holley 780 cfm carb. but thats borderline for a 390. It might be too big (it's new and the price was right, free). You'd be better off (esecially w/ a 360) with something in the 600-650cfm range.
So If can i just order the 390 crank, pistons and all that or is there more to turnin a 360 into a 390? Let me know
if its that easy. I really dont need anything but the crank. the pistons are good to go. the only difference is the stroke right? besides the cam, lifters and gasket kit.
Tim
Old Oct 2, 2012 | 10:43 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Crank and connecting rods to make a 390.
Old Oct 3, 2012 | 07:23 AM
elkarcher1716
thanks thats what i was thinking
Old Oct 3, 2012 | 08:56 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, you need to swap connecting rods too, with the longer 390 stroke the rods are shorter.
Old Oct 3, 2012 | 09:05 AM
elkarcher1716
they are pretty proud of those cranks and that intake you told me about. WOW. time to start saving quick.
Old Oct 3, 2012 | 10:34 AM
garthneddy's Avatar
garthneddy
Instead of using the 390 crank you could utilize the 428 crank and make yourself a 410.
Old Oct 3, 2012 | 11:41 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I went with a plain crank kit from the local parts house. A turned crank, undersized main and rod bearings ran around $225.00. I see Rockauto has a crank kit for the 390 for $238.79 ($188.79 + $50.00 core) It's Standard Crankshaft P/N 15510 and I see rebuilt connecting rods on E-bay for around $35.00 each.
Old Oct 3, 2012 | 11:43 AM
mikeo0o0o0's Avatar
mikeo0o0o0
If you go the 410 route be sure to get the proper flywheel/flexplate. 410-428's are externally balanced and need a counterweighted flywheel.
Casey Hope
Jan 4, 2018 12:23 PM
cmbroo1
Sep 23, 2010 07:00 PM
Copper77
Mar 15, 2007 12:03 PM
jmono
Apr 19, 2006 08:40 PM
falcor1
64
Nov 17, 2005 02:17 PM
