glow plug wiring
Old Dec 8, 2011 | 07:30 PM
harback's Avatar
harback
glow plug wiring
Hello I found a bad pin and melted connector at my valve cover and went to ford to get a new connector and terminals, they said I will have to buy the hole harness is there anyone that has part number from ford or a outside source for these parts? thanks
Old Dec 8, 2011 | 07:34 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
The inside or out side plug?
Old Dec 8, 2011 | 07:38 PM
F350-6's Avatar
F350-6
Welcome to FTE. Yes, you can fix things without wasting your money at the dealer. If you've got a burnt pin, you will need to closely inspect the harness connector both inside and outside the valve cover, as well as the pass thru connector in the valve cover gasket. Odds are you'll need to replace the valve cover gasket and put a pigtail on the harness. If it's the under valve cover harness, it might be worth just replacing the whole thing instead of worrying about splices being sprayed with oil.
You can probably order the parts from your local auto supply store. Dorman makes these products for the chain stores. You can also check with some of our sponsors as they sell the parts too.
Old Dec 8, 2011 | 07:58 PM
harback's Avatar
harback
Thanks for the quick responses,outside connector, and I bought the new valve cover gskt and 2 glow plugs today inside harness looked good .Also I'm considering putting the quarter in there, is there any chance of that falling out?
Old Dec 8, 2011 | 08:07 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here's a link for the plug, And the Valve Cover will hold the Quarter in.
Riffraff Diesel: Valve Cover Gasket Connector Pigtail 99-03
Old Dec 8, 2011 | 08:20 PM
harback's Avatar
harback
Thanks thats what I was looking for.Ihave owned a 97f350 since new and Ijust baught a 2000 f350 it has a few issues but I'm looking forward to upgrading to a 4dr.
Old Dec 8, 2011 | 08:29 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Your Welcome, and BTW welcome to FTE
Old Dec 12, 2011 | 05:11 PM
harback's Avatar
harback
Thanks for the info,a autolite glow plug was broke apart and burned the connector out . 4 new glow plugs, vc gskt and outside connector in 3hrs pretty easy I thought. plus the 25cent mod.
Old Dec 12, 2011 | 09:27 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Good job So we running good now?
Old Dec 13, 2011 | 09:30 AM
harback's Avatar
harback
All is good,started right up at 15 degrees yesterday.I took a picture of the problem parts , how do I post the picture?
Old Dec 13, 2011 | 09:42 AM
bulla's Avatar
bulla
What glo plugs did you replace the bad ones with? Meaning I hope you used motorcraft.
Old Dec 13, 2011 | 10:54 AM
harback's Avatar
harback
I used genuine ford parts and changed out all 4 on the side I had to work on. I'm thinking about leaving the other side alone , they all ohmed out good.
Old Dec 13, 2011 | 11:14 AM
PaysonPSD's Avatar
PaysonPSD
The other side might be autolite GPs as well. You should think about changing those out before they mushroom and won't come out. Autolite GPs are known for that. Then you can check out the UVCH on that side and put in a quarter.
Old Dec 13, 2011 | 11:27 AM
bulla's Avatar
bulla
Sounds like a good idea!
Old Dec 13, 2011 | 12:02 PM
harback's Avatar
harback
by mushroomed do you mean the tips? how would you remove them if I ran into this.
