STEERING COLUMN BUSHING
Old Sep 26, 2012 | 03:42 PM
86fn150's Avatar
86fn150
working on my 86 these pics from this writeup shows a spacer(arrow in first pic).my truck and the few i've checked in town don't have it.also any parts listings don't show it.is it good to have for column support??from what i see the metal backing of the signal switch assm is the only thing touching it on the outer edge.
Old Sep 27, 2012 | 07:16 PM
Franklin2's Avatar
Franklin2
I don't know what it's for, but for column support you need a bearing or bushing inside the metal structure that is attached to the tube, which is mounted to the dash and the rest of the truck. I am assuming the shaft support is inside the metal structure in the picture above.
That piece that the arrow is pointing to is just taking a ride on the shaft, but like I said I don't know what it's for.
Old Sep 27, 2012 | 09:50 PM
86fn150's Avatar
86fn150
the bearings are in good shape ,but just got me wondering about that piece as my parts listings at work don't show it and the columns that i've seen don't have it..but this seems to be a non issue
Old Sep 28, 2012 | 07:20 AM
81ChopTop's Avatar
81ChopTop
The self-canceling ring (black with two pins) pops out of the mulit-function switch at times, when they get worn and old. I wonder if the po had an issue like that and put that piece in there to help prevent that. Looks to be a piece of gray pvc cut to fit. I have never seen a part like that in a Ford column either.
Old Sep 29, 2012 | 03:25 PM
Yaga1973's Avatar
Yaga1973
Elder User - What???
There wasn't any such piece in the column in my truck when I rebuilt it a couple of years ago. Did you have to use a puller to take the steering wheel off?
Old Sep 29, 2012 | 05:33 PM
86fn150's Avatar
86fn150
wheel comes off with a little wiggling.
Old Sep 29, 2012 | 06:51 PM
Yaga1973's Avatar
Yaga1973
Interesting. I wonder if someone put that in as a spacer to raise the steering wheel up a bit so it was easier to get off or to clear something else.
Old Sep 29, 2012 | 07:31 PM
Franklin2's Avatar
Franklin2
Some wheels may come off with a little wiggling, but most need a puller. There are two threaded holes in the wheel for this purpose.
astembridge
21
Jun 17, 2013 10:02 PM
AZPartsLocators
Ford Truck Parts for Sale
Jan 16, 2013 08:41 PM
nmidthune
Jul 6, 2009 12:31 AM
51dueller
Jul 29, 2006 09:32 AM
William
Sep 9, 2005 08:06 AM
