Lower Column Support Bushing
Old Sep 7, 2005 | 07:00 AM
William's Avatar
William
Pulled a PS column from a 75 F100 and need to replace the lower support bushing (plastic). This part installs in the bottom of the column and supports the steering shaft. I remember reading a while back that someone used a sealed roller bearing with a 3/4 inch center and an outside diameter that just squeezed into the column. This seems like a permanent soultion. Does anyone here have information on this? Does anyone here know where I can but a new plastic support bushing? Thanks!
Old Sep 7, 2005 | 08:32 AM
Torque1st's Avatar
Torque1st
Posting Legend
Any plastic supply shop could probably make one out of Nylon or Delrin. Have you tried anyone like Bronco Graveyard or Blue Oval parts?
Old Sep 8, 2005 | 12:44 AM
GeneStoner's Avatar
GeneStoner
This guy I know makes a metal lower column bearing that is super nice for the money ($30). I like mine so far. I'll shoot you this guy's Email address on a PM.
Old Sep 8, 2005 | 01:48 AM
ford390gashog's Avatar
ford390gashog
i made mine out of brass. i used a lathe and a mill . i made these and sold these at swap meets for 25.00 before i lost the use of the lathe. i even cut a groove in the middle of a few drilled a hole tapped it and added a zerk fitting. and then installed it in the tube drilled a hole in the collumn for the zerk then screwed in the zerk.
Old Sep 8, 2005 | 06:56 AM
William's Avatar
William
GeneStoner and ford390gashog! The computer ate the e-mail address! I guess it does that for my own safety? And the brass and grease fitting would be the permanent solution. I do not have acces to a lathe so I am still looking for a resolution to this issue. Thanks Guy's. I remember someone was using a sealed roller bearing that was about 1/2 inche wide, had a 3/4 inch center and an outside diameter that just squeezed into the bottom of the column. Anybody have one of 390gashog's supports laying around?
Old Sep 9, 2005 | 07:43 AM
William's Avatar
William
GeneStoner and ford390gashog! Thank you Gentlemen! I have connected with the Bronco Guy that does the replacement bearings. This problem is solved!
Old Sep 9, 2005 | 08:06 AM
Torque1st's Avatar
Torque1st
Posting Legend
Make sure you give those guys some feedback by clicking on the in their posts. Please add a comment thanking them when you do.
