Overnight clutch problems....
Old Sep 25, 2012 | 06:39 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Ok so this is weird, and the only thing I can think of is the slave cylinder took a ****.
1994 F150 I-6 M5R2 4x4, got everything done on it, full tune up, front clip swap, front brakes etc. etc.
Go for a test drive today, clutch slips REALLY bad in 1st gear, and won't move in other gears.
Yesterday evening, it was driving fine, however I did notice the clutch was at the top of pedal instead of being gradual like when I first drove the truck home after buying it?
So just asking this to confirm this does sound like the slave cylinder is the problem correct? Out comes the tranny for that one
The master is full, and fluid looks good.
Old Sep 25, 2012 | 06:47 PM
White 97 xlt's Avatar
White 97 xlt
My self I would be looking at the master cylinder unless the slave is leaking..
Did you replace the master? If so how was the length of the push rod? It sounds like it could be a little long and not letting the fluid back into the reservoir..
Old Sep 25, 2012 | 06:50 PM
Diesel_Brad's Avatar
Diesel_Brad
I am going to say throw out bearing is jammed in the pressure plate or on input shaft not allowing it to release all the way
Old Sep 25, 2012 | 06:53 PM
IDIDieselJohn
Anyway to see it, if that's the problem? Or shoot some lube up in there without taking the trans out?
I forgot to say in the post, I just pulled out a giant ball of mouse nest stuff from the bell housing, (before the test drive) I don't know if that could of messed anything in there, and i'm clueless of how they even got in there. The drain hole is to small even for a mouse, let alone even getting up there.
Truck has never been parked for any length of time, was used on an auction lot for the last 6 years. So ALOT of clutching has been done.
Old Sep 25, 2012 | 06:56 PM
Diesel_Brad
Pressure plate could be packed full of mouse nest
Old Sep 25, 2012 | 06:57 PM
White 97 xlt
Mouse guts wrapped around the snout of the transmission!!!!!
Yeah, with more info, i'm thinking more about the throw out bearing..
You might back the bolts off that attach the master a couple of turns and see if it makes any difference, if not it's only a few minutes wasted...
Old Sep 26, 2012 | 05:17 PM
IDIDieselJohn
Well I just got done cleaning out the pressure plate, it was indeed full of mouse nest ****.
Now all cleaned out, it's drivable, but still slips abit if you give it alot of gas. So new clutch kit it is..... if I don't get a nice 78 F250 4x4 4 speed that just poped up for sale.
Old Dec 15, 2016 | 11:53 AM
TitanII's Avatar
TitanII
I have a 2004 6.0 with a 6 speed manual transmission. I put a new clutch in 2015. Pickup has 310,000 kilometers on it and always has a gooseneck trailer hooked on it. Clutch quit working yesterday very suddenly. Can mice actually get inside and cause this to happen? Maybe this is my issue...
Thank you for your time.
Old Dec 15, 2016 | 11:59 AM
Freightrain's Avatar
Freightrain
Welcome to the forums.
If it quit suddenly, I would think more of a failure then mice. What does the pedal do? Feel any resistance? Does it slip or not disengage?
Old Dec 15, 2016 | 12:05 PM
TitanII's Avatar
TitanII
There is no resistance when I step the pedal in. Pickup still drives just fine in all the gears, but I have to shift without the clutch. It wont stop the pickup either once moving.
Old Dec 15, 2016 | 01:14 PM
Diesel_Brad
You have a message
Old Dec 15, 2016 | 03:39 PM
IDIDieselJohn
Check the aluminum bracket under the dash, it may have broke. Was pretty common on older Fords with the hydraulic system.
Or the clutch rod bushing that always goes bad on Fords might be gone, and the master cylinder rod just popped out.
nothercrash
Dec 13, 2017 09:30 AM
rosett
Aerostar
Jul 25, 2013 06:37 PM
snookey50
1983 - 2012 Ranger & B-Series
Feb 17, 2007 11:28 AM
saskatchewan
16
Nov 24, 2003 11:41 AM
Talyn
Nov 22, 2003 03:43 PM
