Any Help Appreciated
Problem being that once the temp has gone over 205, if I shut the truck off I get a no start condition till the oil cools. This being a major problem when stopping for fuel on long trips. have changed out the EOT sensor, but that didnt change anything. I am concerned about going in after the oil cooler it's a big job not knowing for sure if thats the problem.
anyone with any troubbleshooting ideas I would greatly appreciate the help. Im Stumped
First, no way should your oil temp go down to 180°. Oil temp should not be lower than coolant temp, since the oil is cooled by the coolant. So if your oil is 180°, your coolant is probably that low also. Which is usually a sign that the thermostat needs replacement.
The no-start when hot is usually a high pressure oil leak, and on an '05 and up, most likely the snap to connect fitting on the HPO pump.
As far as the oil cooler, you have to get the low temp problem corrected, then monitor differential between oil and coolant temps. The simple fact that the oil reaches 230° is meaningless. That temp is within a normal range, assuming the coolant temp is also elevated.
now if I may pester you for a little more info, mainly temperature ranges, my coolant temp also drops when driving through town. my crusing temp on the highway holds steady at 186, which from my expirence seams low.Should the coolant temp remain steady? is that the job of the thermostat?? what is the normal operating temp for coolant? also what are normal operating temps for the oil? I had the understanding that at 240 oil looses viscisity and thats why the temp of 230 worried me.
Also wondering what temp range is normal for oil?
Thanks so much for your help
To do a oil cooler test you need to do this after the truck is warmed up
to operation temps. On a level freeway unloaded go 60 MPH for about 5 min
the EOT and ECT should be no more than 15F delta. The not starting after hot
is a high pressure oil problem and there are some fixes that should be done.
If you are going to do one you may as well do the other at the same time.
STC fitting ,dummy plugs, stand pipes, oil cooler,High pressure filter screen.
The screen is under the oil cooler and the originals were known for failure
Best place to find out more about this and other things would be here >>>
>> 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Have a look in the tech folder lots of good info for the 6.0L
Sean
