Starter Removal - Help!
Old Sep 25, 2012 | 02:35 PM
berick's Avatar
berick
I am flushing my coolant system today and installing the Fumoto drain plugs on the engine block. I got 2 bolts off the starter from underneath the truck but there is a tricky little bugger up top and I can't get a socket or wrench on it for the life of me. Is there a trick to get that sucker out of there?
Old Sep 25, 2012 | 03:02 PM
IslandSchool's Avatar
IslandSchool
On my E350 5.4L Gas I've had the same issue but I've never had to pull the starter on the 6.0L yet.
I used the following and it worked to get it tight and loose but there was a lot (and I mean a lot) of hand tightening and loosening 1/8 a turn at a time.
Socket > long wobble extension > short extension > ratchet
I think I used a universal joint for part of it but got so fed up I took it off.
Old Sep 25, 2012 | 03:04 PM
bismic's Avatar
bismic
Use a 13mm, 6 point medium length socket with a 6" or 7" extension. It does help to use a wobble socket with the extension and an air ratchet. Remember to disconnect the battery first.
Old Sep 25, 2012 | 04:34 PM
berick's Avatar
berick
Got it.... Note to self: buy a wobble extension!
What a giant pain in the a$$ without it. Gonna take a few says for these knuckles to heal. Wow!
Old Sep 25, 2012 | 04:50 PM
bismic's Avatar
bismic
Glad you got it! A good set of wobble sockets are fantastic to have. If you don't use them enough to justify it, then a set of wobble extensions will do.
Old Sep 25, 2012 | 05:20 PM
berick's Avatar
berick
I chuckled reading thru the process in the tech folder... Says the techs do this job in 4.5 hours (or charge 4.5 hours). I have about 3 hours in and I still haven't done my first flush yet! Of course I had to take a few cool-down moments when I was pulling the starter.
Old Sep 25, 2012 | 09:44 PM
Fal-308-Win's Avatar
Fal-308-Win
I read three weeks ago, where the starters fall out by theirself???? You must have a bad one! !!!!!
Old Sep 25, 2012 | 09:55 PM
berick's Avatar
berick
I must have, cuz every one of those bolts was in there good and tight!
Old Sep 25, 2012 | 10:02 PM
Fal-308-Win
Brick thanks for the Belly Laugh ! One rep for you
ScubaTX
16
Dec 30, 2021 08:13 AM
RBerry9511
May 27, 2014 06:17 PM
eco
Garage & Workshop
Mar 13, 2007 09:57 PM
mike5097
Oct 13, 2005 10:37 PM
kingcoda
Sep 5, 2004 09:43 AM
