Water in power steering
There should be a drain tube under the cowl to divert water away from the reservoir. It's probably missing. The power steering flushes we do at work work excellent. If one is not available, remove the return hose on the bottom of the reservoir and let it drain. reattach, refill, start and run vehicle. repeat this as often as needed to remove the water from the system.
jccapri
01-02-2014 09:30 PM
BigMattXXL
Oil & Lubrication
11-24-2002 01:22 AM
otto
02-01-2001 09:33 AM
