side tilt hood
Old Sep 22, 2012 | 10:13 PM
thomc's Avatar
thomc
side tilt hood
I searched but didn't find ,so... Has anyone modified a 53-56 hood to tilt to the side , like a 50 Buick or early 50s IHC truck? The stock hood opening mechanism on my 56 has got to go.I am familiar with the reverse opening mods. Just wondering.Thanks.
Old Sep 22, 2012 | 10:37 PM
topmoo's Avatar
topmoo
Might be hard to get to the hinge side for any work or maintenance. I haven't seen any like that, maybe somebody here has. There is a thread here about some billet hinges that work better than the originals though.
Old Sep 22, 2012 | 10:49 PM
thomc's Avatar
thomc
If it was done like the Buick or IHC I mentioned, the hood can be tilted to either side on both sides can be unlatched and the hood set off completely.
Old Sep 22, 2012 | 11:44 PM
havi's Avatar
havi
I'll have the Roast Duck
I have one on my '54 IH. It rocks! I can't say how it would mount onto a '56, but finding an IH with that set-up, and robbing all the parts might work. Just pick an IH that's beyond repair, lol.
Old Sep 23, 2012 | 09:13 AM
56panelford's Avatar
56panelford
Do you have any pictures of that, sounds like an interesting setup. Would like to see how it works.
Old Sep 23, 2012 | 09:52 AM
havi's Avatar
havi
The base of the latch mounts to a reinforced area of the inner fender. It hinges upward, as you can see where my finger holds it up. The hoodside latch is spring loaded to grab the lower part on the fender. So when one side is unlatched, the other side acts as the hinge, and the hood is lifted up, with a hold-up rod mounted up towards the radiator. These are on both sides, so it all depends on which latch is undone. The handles are on the outside of the hood, and for some, that may be a cosmetic fault. When both latches are undone, neither side acts as the hinge, and so the hood can be lifted off. It can be said, that getting perfect gaps between the hood and surrounding sheetmetal is next to impossible with this setup. But back in the day, function was the rule, lol.
Old Sep 23, 2012 | 10:24 AM
56panelford
It looks like pretty good engineering but looks like it would be quite the challenge to do on a F-100. I'd hate for a gust of wind to come along while the hood is up, might end up in the next couny,lol. Thanks for posting those pictures, it's the first time I've seen that.
Old Sep 23, 2012 | 10:32 AM
havi's Avatar
havi
I agree, and it would probably have to be the whole assembly from a donor truck, and a lot of creative ingenuity to make it work on an F100. But from a practical standpoint, it would be neat to have. Problem, IMO, with the Ford hood is, not only does it go up only so far, but the hinges make the hood move forward a tad, and so it doesn't give much room for reaching in up by the firewall. Good thing Ford put the distributor up front, lol.
Old Sep 23, 2012 | 04:17 PM
Doraville's Avatar
Doraville
To me, the whole reason for doing a hood tilt is to make the engine more accessible. A side tilt hood would make one side more accessible and the other side less accessible.
Now, if you could figure out how to make it tilt to either side depending on the side you want to work on...
-DV
Old Sep 24, 2012 | 12:57 PM
Stephen67's Avatar
Stephen67
That's pretty neat. You would probably need 4 latches total, one for each corner given the shape of the hood, plus it would be safer. Maybe a different latch style too. It would be neat as long as it could be made in a way that's not a pain, the more steps or the more complicated something is, the bigger of a pain it becomes.
A Model T style hood or something, where it hinges off the center line, would be pretty cool as well, but that would change the appearance of things quite a bit, but you might be able to hide it enough on a Black truck or something...
Old Sep 24, 2012 | 03:04 PM
Doraville's Avatar
Doraville
I seem to recall a thread on here a few years ago where someone had split an F1 hood down the middle to allow it to open on either side. It was a novel approach, but I wouldn't want to butcher my hood like that.
-DV
Old Sep 24, 2012 | 09:30 PM
havi's Avatar
havi
'40's Dodge pickup hoods would be a closer resemblance.
The IH hood does tilt on either side, all depends which latch you open. Open both latches and the whole thing comes right off.
Old Sep 25, 2012 | 06:54 AM
Doraville's Avatar
Doraville
I missed that point from the diagram. Very cool!
Old Sep 25, 2012 | 07:02 AM
The Horvaths's Avatar
The Horvaths
Dodge Power Wagons have a split hood too. Best to use two (experienced) people to remove/replace or fingers, paint and windshields may incur the wrath of Murphy.
jakevidrine
May 31, 2018 03:33 AM
Falconry
May 18, 2017 06:55 PM
Mr Mayo
Aug 6, 2008 09:39 PM
PaintedDesert56
32
Feb 15, 2008 12:18 PM
joe hoffman
36
Mar 10, 2006 11:02 PM
