Panel paint, how much?
Old Sep 22, 2012 | 06:14 AM
55paneltrk.'s Avatar
55paneltrk.
Hello gang, im going to try to get the panel painted before the cold sets in. There has to be a panel truck painter in the bunch here. Im going with base coat clear coat. Was wondering how much product for just 1 coat ? Doing the inside - out . Thanks
Old Sep 22, 2012 | 08:50 AM
56panelford's Avatar
56panelford
I bought 1-1/2 gallons of base coat and 3 gallons of clear. I still have to paint my front fenders, grill and gravel pan. I have just over a quart left of the base coat and a gallon of clear left. I sprayed 4 coats of clear on the outside and 3 on the inside. Wet sanded the outside but said the hell with the inside. My spraying technique might not be as good as yours as I ended up with a lot of orange peel. Hope this info is of help.
John
Old Sep 22, 2012 | 08:51 AM
COMPLIT1107's Avatar
COMPLIT1107
Probably 1.5 gal color, 2 gal CC (which allows for a little cutting and buffing of the clear - outside) you should do at least 2-3 coats of clear on outside. What color is base-coat? (may only need 1 gal if close to primer and covers well).
Old Sep 22, 2012 | 08:55 AM
tinman52's Avatar
tinman52
Welder User
Also if you use a "budget" brand of paint it may require more coats to cover....depends on the color.
Nothing worse than running out before you are done....
Old Sep 22, 2012 | 09:00 AM
COMPLIT1107
we posted at same time.. .
Looks like you've almost got it "covered".
If you're crazy.. look here:
https://www.ford-trucks.com/forums/9...d-buffing.html
Old Sep 22, 2012 | 09:01 AM
55paneltrk.
The color is a med. blue metalic. 1gal of color will make 2gal when mixed.
Old Sep 22, 2012 | 07:16 PM
56panelford
I'd still dig deeper in your pocket and purchase an extra quart unless you live next door to your supplier. You could run short or possibly spill some and do a lot of cursing. You'll use any leftovers eventually.
Old Sep 23, 2012 | 08:19 AM
bobj49f2's Avatar
bobj49f2
I want to paint my panel next year and was wondering how much it would take to do the inside and out. I don't remember how much I used to paint my F-2 but I thought I bought 1 1/2 gallons. I painted the entire truck, inside and out of the cab and inside and out of the box with all the fenders.
Old Sep 23, 2012 | 11:56 AM
larryb346's Avatar
larryb346
I think you will need 6 qts at a minimum. I would get 7 to be safe and it might need a full two gal. I used 6 qts. in my 55 and sprayed the entire truck,and inside the cab. My silver metal-flake will cover about the same as your blue. You want enough to cover well. You will also want to mix all you paint together after you get it home. If you get 6 or 7 qts. mix it with the gal to get all the same as sometimes when they mix paint they are off slightly between gal mix and qt. mixes.
Larry
JTB321
Aug 6, 2019 04:45 PM
Itsmyford
Nov 26, 2018 06:36 AM
Tparkin99
15
May 15, 2016 07:27 PM
BogTroll
Feb 24, 2014 10:43 PM
gdub
Sep 6, 2011 10:31 AM
