Project: he351ve turbo
#241
91dirtydiesel, I've been thinking a lot about your Arduino board to control the vanes. I'm pretty well versed in writing code for Arduino and picaxe chips so I was thinking a little mix of using the tps (or adding a tps if you have a manual) for throttle input, and rpm sensor for engine speed engagment. Together I could probably setup a code that would make it so the vanes are tight for low rpm and high fuel, and open vanes for higher rpms like 2k+ rpm and light-medium fuel...or however the vanes would work best. From what I read there are guys that have done a similar setup when adding a ve turbo to their trucks. Maybe I'll run down and buy another Arduino to code using my truck as the guinnepig since I have an auto (have tps). Could easily add LEDs to indicate where the VE is currently set at while you're driving. I'll post more when I get somewhere on this in my free time.
#242
Hey thanks, yea I was thinking I'd need rpm too because when I'd let out the throttle going down hill or something the rpms stay up, with my manual tranny. Going down hit at 50 it still reads 4-6psi so if it shut it would basically be like an engine brake. Do you think using a stepper motor would be best? I was planning on rigging up an electronic actuator
#243
#244
hey 91 im not sure how much you have drivin lately but im sure alot of us are wanting to know the same thing and im going to ask it................. FUEL MILEAGE. is it better now that your pushing 1psi at idle or has it gotten worse. im mainly asking because im also thinking of putting one of these bad boys on my truck. not only would it make it sound meaner but make this sucker look meaner. ive done a bit lately to my truck and i really need to post up some pictures in my garage but im liking the way my truck is turning out. and honestly want to know how well yours is doing. im thinking about sticking one of racin's cams i beleive who it was who made them in there so that would do alot of good with this turbo idea .
#245
#247
I cant imagine a tuned VGT causing poor fuel economy. I was looking at a vid of the Fleece MAP only standalone version, its pretty cool, has a couple different setting. In a nutshell you have : tight - high fast boost, DD typical good all around, open- for cruising down the hwy it opens up and boost is at 0-1 for max mpg's
#248
easier said then done! I love driving against the boost...Cant wait too see this finished up and working got my eye on Craigslist.
more fuel, studs, and R&D IDI Perfromance stickers. can't go wrong with that combo.
#249
#250
The NOT win of course would be the $900 price tag. I dont know how much the MAP only unit is though, 88Ford did you ever call them and find out? But, once you get it on and dialed.. never have to look back. Working exhaust brake, adjustability on the fly
#251
#252
Right Brandon???
#255
Maybe the location of the VGT controller is in a hard area? I'm trying to find pictures to confirm.
