Sponsored by: Real Truck
headlight problems
Old Sep 21, 2012 | 10:22 AM
f350Super99's Avatar
f350Super99
headlight problems
Hey all
I updated the front end on my XL to composite headlights and i'm having a problem with the passenger side the light is only getting 6 volts all the fuses are good, wires look good any thing else I can check?
Old Sep 21, 2012 | 08:55 PM
f350Super99
any one?
it was working but then it stopped?
Old Sep 21, 2012 | 10:01 PM
Punisher29073's Avatar
Punisher29073
I have see bad grounds cause low voltage problems. Where are you checking the voltage?
Old Sep 21, 2012 | 10:02 PM
f350Super99
at the plug for the bulb
Old Sep 22, 2012 | 12:19 AM
Yahiko's Avatar
Yahiko
Check the connectors/splices between the light and the fuse for that circuit
You have a high resistance some where on that line. Also check you
ground to the battery (-) it could be there also.
Sean
Kilomanjaro
Feb 23, 2022 12:14 PM
tigers3535
Escape & Escape Hybrid
Nov 4, 2014 11:11 PM
bigfoot22
Mar 28, 2010 03:59 PM
Alberta dave
Mar 12, 2004 07:40 PM
