Anyone ever have problems with the low beams on your headlights go real dim sometime and then get real bright and go back to being dim again.I checked the wiring to the headlights and it's okay.Any Idea's?
Thanks for your help-Ken
Find where the lights are grounded and clean the connection. Check for corrosion on the the fuse holder. The only other place I can think of would be in the would be in the light switch itself.
Just the low beams.I see that wire on top of the radiator.I'm going to clean the wire's this afternoon or tomorrow morning and see if that helps.Thanks guy's for the help.-Ken
Is there any way to check the voltage reg. to see if it's going bad?
If it is only happening on low beams, the dimmer switch or connection to it is the most likely culprit. Grounds and everything else is common to the high beams.
