bulletproof egr cooler, now it wont run
Old Sep 20, 2012 | 03:46 PM
nickPSD's Avatar
nickPSD
I got suckered into helping a friend do the bulletproof egr cooler on his truck. When it was all said and done it started for about 1-2 seconds then died, now it will only crank and not restart. I have not hooked my Genesis scan tool up yet, but will probally try that this weekend. Any help? I did my own truck and didnt have any issues with that one
Old Sep 20, 2012 | 05:23 PM
Rusty Axlerod's Avatar
Rusty Axlerod
So many things it could be. Almost dead in the water without some sort of scanner. I would read throught the no-start thread in the tech folder.
Old Sep 20, 2012 | 05:28 PM
m-chan68's Avatar
m-chan68
Did you replace only the EGR cooler alone, or did you replace both the EGR cooler and the oil cooler?
Old Sep 20, 2012 | 05:49 PM
nickPSD's Avatar
nickPSD
Did the oil cooler also, I didnt have to do the oil cooler on mine since it was done less than 1000 miles before that.
Old Sep 20, 2012 | 06:51 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Recheck every sensor you unplugged. Did you have to remove FICM? Make sure those were seated properly. And it's ground wire.
Old Sep 20, 2012 | 07:55 PM
BLADE35's Avatar
BLADE35
Originally Posted by nickPSD
Did the oil cooler also, .
Odds are High junk got into the HPO system and jacked the IPR Up
Pull IPR check the screen
very common after this Oil Cooler R&R
Old Sep 20, 2012 | 08:50 PM
bismic's Avatar
bismic
How many cranks have you tried and for how long?
Old Sep 21, 2012 | 10:42 AM
BLADE35's Avatar
BLADE35
Would be good to know this too^^^^^
I assume that since you did your Oil Cooler you know about the Long Crank to get the HPO system filled back up and get started again
Jimbo532
Jul 16, 2013 04:13 PM
semperstrokin
Sep 15, 2011 09:53 AM
04scurs
Mar 19, 2011 05:02 AM
Jbru167
Dec 7, 2010 04:24 PM
