c1676???
Old Sep 19, 2012 | 06:50 PM
00awdexpo's Avatar
00awdexpo
c1676???
have a 2000 awd expo 5.4 only code im getting is a c1676. the od light blinks after warm up around 10 minutes. have problem with torque converter solenoid. changed solenoid pack, problem solved. everynow and then it wants to stall at a light like your not mashing the clutch in and pulling it out of 5th, even though its an automatic. had problem with it not starting. turn key nothing. screwdriver to the starter relay starts right up. ignition switch fuse is good. 15amp. pulled connector off of transmission range sensor blew it out and now it starts. i could run the shifter through the gears leave it in neutral and it would start so thought of the neutral safety switch so i cleaned TR sensor. my abs light doesnt come on but im getting an abs code (buld could be blowed?) the 4x4 light blinks after 20 mins 4high and 4 low work but no low range light on the dash (bulb could be blowed?) no blown fuses under dash or hood. im open to any theories and at this point i cant find anything in the forums with just a c1676 code.. any ideas?????
superv10
Nov 11, 2014 10:33 AM
trapperack
Dec 24, 2009 04:35 PM
Smash15e
Feb 2, 2005 06:23 PM
smitch466
1997 - 2003 F150
Aug 29, 2003 07:34 PM
Wiseman
1997 - 2003 F150
Aug 22, 2003 03:05 PM
