increaded boost
Old Oct 9, 2012 | 03:41 PM
trekbasso's Avatar
trekbasso
Hi all,
I need to open this one more time. Can someone provide a link to the install 10k mod?
My ADD keeps redirecting my searches and I can't seem to find the how to.
Thanks.
Old Oct 9, 2012 | 04:02 PM
CSIPSD's Avatar
CSIPSD
Why do you want to install a 10k mod with your tuner? It will gain you little and cause SES lights...
Old Oct 9, 2012 | 08:20 PM
trekbasso's Avatar
trekbasso
Exploring possible options until I can afford to do something else. That is what got me started with this whole mess (mods,etc) someone talks about doing something etc etc.
The only good info I can find on the 10k concerns e99 and earlier.
So, I'm listening, would it defeat the tunes? Or just not help at this time given what I am running?
Old Oct 9, 2012 | 08:39 PM
CSIPSD's Avatar
CSIPSD
If your running ANY tuner right now, all a 10k mod is going to do is cause you to get a SES light for ICP pressure, possible hard shifts and more smoke.
Just skip it man, its not going to help.
Old Oct 9, 2012 | 09:11 PM
trekbasso's Avatar
trekbasso
Good enough for me, thanks Joe. And, well stated.
Old Oct 14, 2012 | 07:31 AM
timmyboy76's Avatar
timmyboy76
THOUGHT, the ICP was the culprit, but no dice. However, the truck seems to be a hellofalot quieter, and throttle seems more smooooth.
Old Oct 14, 2012 | 10:06 AM
SkySkiJason's Avatar
SkySkiJason
I had 10k on a SPDT switch (10k/off/15k) for a couple years, until I got a tuner. Yes, it improves throttle response and gave me at least a few psi more boost when turned on. Before I had gauges, I turned it OFF when towing 'cause I was afraid of EGT increase...
Fwiw, the tuners change ICP - just in a more complex way than 10k can. I even played with a 5k resistor a little, that made a HUGE difference LOL!
Also, cramming the resistor into the plug is a bad idea. If you're gonna do this 'cheap mod' I'd strongly recommend stripping the wires a little and soldering the resistor in - then use liquid electrical tape to seal it up. You can always remove the resistor later and reseal the wires w/more liquid tape.
jhobbs26
Mar 11, 2013 08:24 AM
JonathanN
Jun 18, 2010 03:52 PM
biggietx
Mar 3, 2008 06:46 PM
TN_F250
24
Nov 12, 2007 02:57 PM
pamelbert
Jan 5, 2006 07:59 AM
