50 Cent Mod
Old Oct 13, 2012 | 09:19 PM
preppypyro's Avatar
preppypyro
50 Cent Mod
Hey guys and gals,
Just wanted to post a thread in here, cause I havent for quite a while, and I used too all the time.
My truck threw the CEL a couple times in the past few days, I did a quick search on FTE about the uvch problems and decided to tackle the 50 cent mod.
It was pretty easy, a couple of pain in the *** bolts, the passenger side valve cover wiggled out with out too much hassle. I had to grind our Canadian quarters down a little more (then what I seen in the pictures here) but it worked perfect.
I did the passenger side first, and it was actually ok. The drivers side was my problem, and the quarter repaired it perfectly, for now anyways!.
Also retorqued everything under the valve covers, and i may be smoking crack, but the truck seems more responsive. Some of those bolts took a full turn to torque to spec!
I also took all the heat wrapping crap off of the tube, and it whistle's a little louder then I like, but c'est la vie!
Anyways just wanted to give a good experience, and a thanks to the threads created to help me through this pretty easy modification!
Old Oct 13, 2012 | 09:24 PM
Turfzilla's Avatar
Turfzilla
What code were you throwing?
Old Oct 13, 2012 | 09:30 PM
preppypyro's Avatar
preppypyro
No idea. I never have bought an AE (should have, but never did).
Just read through a couple of threads, and thought that I would give the most common issue a try.
I was bored last night and my baby fell asleep early, so i decided to start yanking VC's off, and check around.
I love wrenching, and the 7.3 is a terrible engine to wrench on in my experience, because the damn thing never breaks down!
So I figured Id get in there, do the mod, and if it didnt work, then I would take the next step.
Forgot to add in my first post, airing down the tires so they were flat, was such a help for me. Im 6'3, running my winter tires and rims (285/75/16) and I was having a terrible time reaching those far back bolts.
Old Oct 13, 2012 | 10:02 PM
F350-6's Avatar
F350-6
Congrats on the fix.
Originally Posted by preppypyro
I love wrenching, and the 7.3 is a terrible engine to wrench on in my experience...
You're right. The newer trucks are so much better. Here's a pic from a local Ford diesel mechanic showing how easy (and common) it is to work on a 6.4 diesel.
You know, it's actually easier to just find a small step to stand on than to air down the tires.
Old Oct 13, 2012 | 10:32 PM
preppypyro's Avatar
preppypyro
Here I thought the 6.4 was mor ereliable then the 6.0, doesnt look like it!
Chris, you would be surprised at the lack of steps I had around. I actually went and got my weight lifting bench and used that haha.
Airing the tires down worked ok, needed to check the pressures anyways
Old Oct 13, 2012 | 11:41 PM
Franko72's Avatar
Franko72
Molon Labe
Ford should have hinged the cab like an old cab over semi. What a stupid design...
Old Oct 14, 2012 | 09:22 AM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Rotating the air in the tires is an often overlooked PM item. Don't forget the spare.
Good job Sheldon and tsk tsk to you Chris. I expect better from you buddy.
Franko mod.....hinged cab?????
Old Oct 14, 2012 | 11:13 AM
ToMang07's Avatar
ToMang07
Probably overdue for a muffler bearing, too.
Old Oct 14, 2012 | 11:18 AM
UP_There's Avatar
UP_There
this is a simple mod that I've never tackled! Never had a reason to actually.....I guess one of these days I should start digging around in there like you did Sheldon
Old Oct 14, 2012 | 11:49 AM
preppypyro's Avatar
preppypyro
Travis your truck is pretty tall, you might have a fun time laying under the hood!
Easy as pie though buddy!
Old Oct 14, 2012 | 12:13 PM
UP_There's Avatar
UP_There
flattening my tires might just overheat the compressor too!
maplemale
Jul 5, 2017 07:59 PM
Splatts
49
Feb 6, 2012 01:56 AM
ronjon95
16
Aug 20, 2011 07:06 PM
omanalansan
19
Aug 18, 2011 07:37 PM
Orezona
26
Aug 19, 2008 09:42 PM
