Is this stock?? Rocker Inner Panel?
It's really hard for me to tell what's stock and what's not with so much rot on the floor of this cab.
Is this inner panel stock or did P/O add it?
Thanks.
http://www.flickr.com/photos/87235736@N02/8001374927/http://www.flickr.com/photos/87235736@N02/8001374927/ by http://www.flickr.com/people/87235736@N02/, on Flickr
Thanks.
Greg,
Not sure which you are referring to as I look at your pics.
On the pic you posted, you are showing 1/2 of a rocker below the floor that would face the door. Mine has a full length rocker, single wall, there that has the lower door seal track in it. I just went out and looked and it is a part of the floor (90 degree bend of the original floor pan), not welded the floor pan. It measures 4 1/8" top of the floor to bottom of the lower rocker bend the entire length.
If you are referring to the panels in the back of the cab (look like patches), the rear wall is single wall/piece also.
It's the painted black metal. I've already cut the complete rocker panel away. The half piece metal you see was behind it. It looks to be a patch panel for the floor that 90's down and ties into the outer rocker panel. \
Oh well, it's welded in to the floor pretty good so I guess I'll leave it. Just a sturdier floor now I guess.
Thanks.
Thanks.
Uni Moe
12-29-2014 05:35 PM
