Outer Floor Replacement Help
Old Jun 21, 2013 | 11:36 AM
ToddGatman's Avatar
ToddGatman
New to this, so I need an education. I have an '88 F250. Overall the truck is great shape, but underneath there is rust on the floor pans out against the rocker panel. I don't understand what I'm looking at in order to get replacement parts. There is a flange turned downward that is spot welded against the body and the rust is through this panel. Do I need an outer floor pan replacement? Inner Rocker panel? I don't know how the truck body is put together here, so I don't know what I need. As I understand it, you see the rocker panel from outside the truck, so does the assembly go like this; rocker panel--->inner rocker panel--->floor pan? Can someone explain this to me please?
Thanks,
Todd
Old Jun 22, 2013 | 06:15 AM
JWA's Avatar
JWA
Hey Todd!
Hard for me to picture what you're describing however if you can locate a Mitchell Collision Guide for your year vehicle it will show individual pieces used in constructing your cab.
A body shop specializing in older vehicles would most likely have such a thing--they might let you thumb through it without cost.
Hope this is helpful!
mwoj
May 13, 2017 09:23 PM
gregstith
Sep 19, 2012 06:52 PM
sbishop
Paint & Bodywork
Dec 6, 2007 06:29 AM
RLord4268
Paint & Bodywork
Mar 17, 2006 07:38 AM
RLord4268
Paint & Bodywork
Oct 12, 2005 07:27 AM
