Cheaper tapered blocks from Ford
Old Sep 18, 2012 | 12:27 PM
housedad's Avatar
housedad
I was going to order some tapered blocks for the rear of my Ex. I have it all leveled out with 4 inches of lift in the front (1.5 inches from V codes, 2 1/2" from a full length spring pack) and my modded B codes.
But it just doesn't look right to me. I find that I like the tail a bit higher than the front.
So I started looking around at all the threads and found these part numbers:
Left Tapered Block: F81Z5598FA
Right Tapered Block: F81Z5598GA
It is listed on the Ford parts dealers sites as "spacer 4WD, 137, 142" wheelbase"
Now, while looking around and comparing prices, I noticed that those numbers are for the 1999 through 2001 F350 models.
Current prices at Tousley ford are $63.88 for the left and $61.02 for the right.
However, If you look at 2002 and above, you get a really different price if you drill down through the menu and choose the part by application.
For the 2002 through 2004 F350:
spacer 4WD, 137, 142" wheelbase Left $42.79
spacer 4WD, 137, 142" wheelbase Right $31.24
Now, those prices are closer to the flat (non tapered) blocks as shown in this listing:
2004 Ford F350 Super Duty - 13245005 Rear suspension - with auxiliary
Those cheaper blocks, 3Z-5598-CA and 3Z-5598-BA (LH, 4x4 - 137", 142" WB - DRW, FROM 1/23/02, 2002/ 2004 ; Ford 350 Series) in the listing above are shown as no longer available.
Makes ya wonder, don't it? What is Ford thinking?
BTW, Tousley ford is the cheapest I found.
Old Sep 18, 2012 | 01:08 PM
EXv10's Avatar
EXv10
Lots of things determine prices.
Old Sep 18, 2012 | 02:06 PM
Treker58's Avatar
Treker58
Made in the USA 1999/2001, outsourced in 2002
WA_PSD
May 8, 2016 08:30 PM
DAVE67FD
Mar 10, 2009 03:49 PM
cableguy17866
Feb 23, 2007 11:44 PM
RIS
Jul 5, 2004 01:29 AM
hdway
Jun 22, 2004 10:41 PM
