Sponsored by: Real Truck
3" block part # needed
Old Jul 4, 2004 | 07:25 AM
RIS's Avatar
RIS
The dealer in Gulfport, MS. said there isn't a 3" block for a SD. I'm being told there is. So who knows best? The people here! Part # anyone?
THANKS!
Old Jul 4, 2004 | 07:49 AM
FF-Paramedic's Avatar
FF-Paramedic
There are 2" blocks (actually measure a little less) standard on F250's and and what people are calling 4" blocks (actually a little less when measured) that are standard on F350's. They come in tapered and non-tapered, depending on the wheelbase of the vehicle, to keep the drive components in correct alignment.
I had the same problem with FMC's parts lists when I bought my 4" blocks. The F250 and F350 show the same part number in the parts lists even though the vehicles have different thickness blocks. Parts guy didn't believe it until we crawled under new trucks on the lot.
The part numbers for the 4" blocks (if you're raising an F250) are:
137" & 142" WB
F81Z-5598-GA(L) (tapered)
F81Z-5598-FA(R) (tapered)
156", 158", & 172" WB
F81Z-5598-DA (L & R) (non-tapered)
Not sure on the correct part numbers for the 2" blocks (if you're lowering an F350).
Hope this helps.
Old Jul 5, 2004 | 01:29 AM
RIS's Avatar
RIS
THANKS AGAIN! I'll pass this on to my "Bud!" who asked me about it.
RIS
