regen question
Old Sep 14, 2012 | 10:39 PM
gowesley's Avatar
gowesley
regen question
I know this has been disussed before, I was wondering how many out there has there turbo pressure gauge surge up and down in regen with the cruise control on, mine is a 2012 350 with 4400 miles and it does it, it doesnt bother me, I usually disengage the cruise till the regen is complete, also has anyone had a cure for this.
Old Sep 14, 2012 | 11:29 PM
Andrew010's Avatar
Andrew010
Delete the emissions crap, then it won't surge with the cruise on!
Old Sep 15, 2012 | 12:17 AM
kper05's Avatar
kper05
Same with my 2011.
You hear the turbo and see the gauge move more than you feel it as strange is that is but you can slightly feel it.
I've gotten use to it but I am curious why it does it.
Old Sep 15, 2012 | 12:46 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Level road....cruise on..... boost pressure goes up & down.
I pulled over. Turned off the engine. Waited 15 secs. Restarted the engine. Problem gone.
Has happened 3 times. Told the service folks... They have heard of it. Do not have a cure. Ford is aware of it....no solution yet.
F-350..... 1 year old.......16000 miles
Old Sep 15, 2012 | 07:19 AM
Hdslider's Avatar
Hdslider
My thought as to why it does it, is during regen it is.injecting fuel in pulses during regen, dumps more fuel then pauses causing like a bog down.so the cruise is trying to compensate for it.
Old Sep 16, 2012 | 05:09 AM
CornTruckDriver's Avatar
CornTruckDriver
Sailor_Roy, Why are your rep things a different color than the rest. Changed now, that's weird.
Old Sep 16, 2012 | 11:46 AM
parkland's Avatar
parkland
passive regen?
Old Sep 16, 2012 | 08:15 PM
kper05's Avatar
kper05
Originally Posted by parkland
passive regen?
No, active regen.
Passive occurs when EGT's are high and that's all it needs to clean out soot.
MNDiesel2
6.7L Power Stroke Diesel
Jun 25, 2013 09:18 PM
fougazi
30
Apr 10, 2013 10:55 PM
DBWinIN
Dec 2, 2012 04:18 PM
MNDiesel2
Sep 15, 2011 05:52 AM
Roody727
Jan 3, 2011 06:07 PM
